Sizing a Backhoe Thumb Cylinder
   / Sizing a Backhoe Thumb Cylinder #1
Dougster
MA
2004 Mahindra 4110 w/509 BH
I've got a Bradco 509 BH with a fixed thumb that I want to convert to hydraulic. Buying the fully integrated Bradco conversion kit is out of the question due to cost and complexity. I've added a second rear remote set for that purpose and for other needs... but not being integrated, there is some question about how to size and select the new thumb cylinder for: a) correct applied force and b) maximum physical strength and prevention of system damage or breakage.
Because the Bradco system is fully integrated into the BH hydraulics subsystem, proper design and controls prevent the hydraulic thumb hydraulics from overpowering and damaging the bucket hydraulics and vice versa. But with a completely separate control valve running the hydraulic thumb, this leaves some questions that even Bradco could not (or would not) answer about how to properly size and select the new cylinder.
Any thoughts on how you might approach this question are most appreciated. :)
Dougster
   / Sizing a Backhoe Thumb Cylinder #2
Bunch of questions:
1. System max operating pressure(for available energy)?
2. Size of existing bucket curl cylinder(for available applied cylinder force)?
3. Distance from bucket pivot to cylinder link attachment(for mechanical
leverage advantage to the bucket?
4. Distance from bucket pivot to bucket lip/rippers(for mechanical leverage
loss from the bucket)?
5. Size of dipper tube, dimension and wall thickness(for determining dipper
strength)?
By multiplying the piston area (Radius squared X PI) by the system max pressure, you can determine the force applied by the ram.
Determining the mechanical loss in the bucket(distance from rippers to pivot divided by distance from bucket pivot to cylinder link attachment) and divide the applied force from the ram by this number to determine the force applied to the ripper edge of the bucket.
You can do the same thing with the thumb arm, figure the mechanical loss based on attachment point of the hydraulic ram then size the thumb cylinder diameter so the thumb arm can't apply more force out where it meets the bucket lip than the bucket can apply.
The dipper and structure dimensions are just to get an idea of how strong the structure is. The dipper structure is mostly in tension(strongest mode) when the bucket is curling, especially if it is pushing against/pushed by a thumb.
   / Sizing a Backhoe Thumb Cylinder #3
Dougster:
As an ME you are probably way ahead of me on this, but here are my thoughts.
I presume Bradco sized the bucket curl cylinder and set the system relief valve so that when the bucket is deadheaded against the thumb (or against something solid between it and the thumb) the force on the bucket does not exceed some design limit. If that is true, then don't you have to just make sure the movable thumb can't exceed that force on the bucket?
Can't that limit be achieved hydraulically by plumbing a relief valve in the curl cylinder base circuit (the one that closes the bucket) that dumps overpressure into the curl cylinder rod circuit through a check valve and (since the base circuit will produce more fluid than the rod circuit can accept when the piston moves) and also dumps into the reservoir? When the relief valve setting is reached, fluid will flow out of the base end of the curl cylinder to two places: the rod end of the cylinder through the check valve to the extent needed to fill the rod cavity, and balance to the tank.
But isn't the mechanical solution just to calculate the maximum force on the bucket cutting edge when it contacts the fixed thumb (or perhaps when the cylinder rod, measured on the perpendicular, is furthest from the bucket pivot, which will be the point of maximum torque) and then size the thumb cylinder (using the system relief setting that applies to the source of fluid for the thumb)to limit the force produced by the thumb on the bucket to the same amount or perhaps a bit less?
RonMar said:
Bunch of questions:
strength)?
Thanks Ron... Excellent thought process. :) You have done this before... yes? :D Just a couple questions:
1) I believe you are recommended that I match the force that can be applied at the worst case joining point, assumed to be the bucket lip for now... correct? One thing that bothers me about this is that Bradco allows more force to be applied to/by the fixed thumb than to/by the hydraulic thumb... 80% to be exact... hydraulic vs. fixed. The reason for this is not entirely clear. It could be strength of components or it could simply be the smaller diameter cylinder they put on the hydraulic. One thing for sure: The thumb geometry is considerably different on the hydraulic vs. the fixed arrangement. To be safe, should I use the same 80% criteria as Bradco? Or does that risk physical damage to the thumb hydraulic components in this separated (i.e., non-integrated) control scheme? :confused:
2) I understand the importance and implications of cylinder diameter (ID)... but what about cylinder design pressure rating and piston rod size? Any thoughts there? My tractor hydraulic system operates at ~2,000 PSIG (relief crack setpoint) to ~2,300 PSIG (full relief valve setpoint)... both values approximate and unverified. Published design pressure of the Bradco subsystem is 2,500 PSIG. Would you buy a higher rated thumb cylinder given the accidental risk of overpressurization by excessive bucket force against a closed thumb subsystem? Or should I keep it the same and take the hit there lest I inadvertantly damage other, more costly components?
Or is the real answer some sort of supplementary relief system? :confused:
Dougster
Farmerford said:
Dougster: As an ME you are probably way ahead of me on this, but here are my thoughts.
I am never too proud or overconfident NOT to ask the fine, experienced people here to confirm, assist or supplement my own thought process. :) That sort of thinking comes with age. ;)
That much is clear. There is no way we want the thumb cylinder to be able to place more force on the bucket lip than the bucket cylinder.
Unless necessary (and maybe it is), I would prefer not to add any further relief capability into the bucket circuit. From my discussions with Bradco... and the apparent need for me to keep the thumb-imposed force (at lip) below the bucket-imposed force... I think I am covered.
Exactly correct. Great minds think alike. :) The basic design criteria in that regard is fairly clear... but the "trick" of it (for lack of a word that can't be published) is all in the component selection (and added relief?) details. :cool:
Dougster
   / Sizing a Backhoe Thumb Cylinder #6
Dougster
That is a very good question. My thought process hadn't rolled far enough along to include that scenario. For the sake of remaining simple, I would avoid any additional relief system if possible.
The force applied to a closed thumb system would come from the bucket system which is limited by the system relief pressure setting. A fixed thumb can withstand the bucket curl force and stops the bucket travel and opens the relief right? You will need a heavy enough hydraulic thumb structure and cylinder to withstand the potential closed circuit pressure from the force applied by the bucket without exceeding safe rated component pressure in that closed circuit. And vis versa for thumb pushing against closed bucket circuit.
I guess it would be best to match the thumbs maximum applied force to that of the buckets maximum applied force. That way the closed system on either side should be able to withstand the force/pressure applied by the driven system without exceeding pressure limits.
   / Sizing a Backhoe Thumb Cylinder #7
I am just finishing up my 3rd Generation backhoe thumb, which
will be an hydraulic version of my fixed or articulated thumb. Some
comments come to mind as I read this thread:
> don't get into an "analysis paralysis" situation when doing your
design. It is not that complicated.
> the forces exerted by the thumb cylinder will vary as the thumb goes
thru its arc. Your thumb needs to be strong enough but also
retract far enough to get out of the way, while not hitting the
dipper. These are conflicting parameters.
> I like welded cyls for this application and Surplus Center had some
3000psi 2x8 cyls for sale for only $45. I bought several. This is a
slightly larger ID than my curl cyl, but the bkt curl will have more leverage
thru most of its arc. I do not know the max pressure specs for my
curl cyl. It is prob not stated for the Bradco either. I doubt they are
the cheapo 2500psi cyls since the Bradco and my Prairie Dogs handle
2500psi wp by design. What is the 509's curl cyl OD?
> if you are concerned about overpressure damage to your thumb
cyl, consider using a shock relief valve on the retract side of the thumb
valve you will be installing. I don't think it is necessary myself.
> In my design, I am using a poppet style solenoid valve connected to
the curl cyl ckt so the thumb cyl operates in parallel with the curl cyl.
One advantage that offers is both jaws close at the same time.
   / Sizing a Backhoe Thumb Cylinder #8
Dougster,
I realize that your Bradco 509 isn't the same as my Woods BH90-X, but for reference, my hyd thumb cylinder dimensions are 2.5 x 1.5 x 16.75.
Also, you can refer to Woods' hyd thumb installation manual to get an idea of how they've plumbed it into the BH, http://www.woodsequipment.com/Manuals/manuals/SubFrames/MAN0540.pdf.
Hope this may help give you an idea of how they've done it.
   / Sizing a Backhoe Thumb Cylinder #9
dfkrug:
That's an interesting twist to use poppet valves to put the thumb and bucket cylinders in parallel. I have wanted to try that with the backhoe on my John Deere 455D, but I was hesitant to spend the time (and money) modifying the existing setup without knowing how it would work. Are the cylinders on the bucket and thumb about the same size? How do the bucket and thumb respond? That is, do both move until one strikes the target and then the other one closes up to complete the grasp? When you release do both open at about the same speed or does the thumb, being lighter, move first? If you want to retract the thumb fully, I assume you open the valves and retract all the way; then close the valves to hold the thumb in the retracted position? Finally, if you extend the stick and boom so that the "claw" is horizontal (or close), do the bucket and thumb swing down with the weight of the load? Or do you close the poppet valves to prevent that?
I agree with our advice to Dougster to avoid overanalyzing the deal. The only place I might disagree is regarding the relief valve in the thumb circuit: it would be easy (since you are plumbing the thumb anyway) to put an adjustable relief valve across the thumb work ports. That way you could oversize the thumb cylinder a bit and then control thumb pressure with the relief valve rather than relying on precise calculations for the moment arms, etc.
   / Sizing a Backhoe Thumb Cylinder #10
My design is done and I have the cylinder ready, but I have not received
my solenoid valve yet, so stay tuned. It IS an experiment, so I have not
verified all my intended results yet. My cyls are very close in size at 2" ID.
My plan is to use ONE poppet valve (rather than a solenoid spool valve) on
only one side of the thumb cyl. A toggle switch on my console will switch
betw a fixed thumb (retracted or not), and a thumb that moves with the
bucket. Note that poppet style solenoid valves allow some leakage under
pressure in one direction. I am planning for that by installing it in the
proper direction so it will hold in the fully retracted position.
As for how it would operate, I anticipate that with nothing to grab, the
bkt would close first most of the time due to gravity. The neat thing
is you are able to put more even pressure on what you are grasping. As
soon as the bkt touches the object, the thumb starts moving, or vice
versa.
I would have gone with a separate manual spool valve on the console
but I do not like hoses on the outside of boom and dipper and I don't see
a very good way to mount and operate the valve. (I would like to try
the Woods valve, but I have not had the oppy.)
I agree you can adjust the thumb force with a relief across the
work ports. I don't think is it all that valuable as you should make the
thumb robust enough for full system pressure. Note that hoe manufacturers
do not seem to offer this option for the curl or thumb cyls.
Correct
Also absolutely correct... or I'll need to provide relief.
This shouldn't be an issue... but in theory you are correct.
... and yet Bradco reduces that thumb-applied force by 20%... why? :confused:
Dougster
Some very good comments and suggestions here. I have been following your backhoe thumb project... and Ron's... almost from the beginning. I admire you both for your creative, innovative designs. :)
Because I have the Bradco fixed thumb already and am just converting it to hydraulic, there is not much to think about in terms of geometry (e.g., no funky retraction issues, etc.). Bradco has done all that for me. But you probably know that the Bradco kit includes a fully self-contained control system... whereas economics and sanity dictate my use of my new rear remote set. Some have said just to copy the Bradco hydraulic thumb cylinder exactly and be done with it. Unfortunately, being an engineer, I have to understand what I'm doing and possibly even improve a bit on the Bradco kit... but never at the cost of safety or possible equipment damage.
I see no big need to economize or compromise in my selection of a cylinder as no matter how you slice it this conversion is not going to be all that expensive since I am using the second remote set. If I can get a cylinder at a good discount, great! But so far I haven't seen anything anywhere that was close enough to my envisioned need.
The shock relief valve sounds like a good idea to me. I will look into it. Your idea on the solenoid valve is also very good, but unnecessary in my case. For me, simple is good. :)
Dougster
MadDogDriver said:
Dougster,
Thanks very much for the reference! :) Length and stroke are easy... I can measure them right off what I've already got. Plus they should match the Bradco kit cylinder anyway or I better understand why not! :D Cylinder diameter and rod size are slightly trickier. On design rating, at this point I think I should go with 3,000 lb unless someone gives me a good reason to do otherwise. :cool:
Dougster
dfkrug said:
I agree you can adjust the thumb force with a relief across the work ports. I don't think is it all that valuable as you should make the thumb robust enough for full system pressure. Note that hoe manufacturers do not seem to offer this option for the curl or thumb cyls.
With my "belt and suspenders" nature... the idea of building for maximum possible pressure PLUS having a system relief valve anyway... makes me very happy. That was the way it always had to be done back in my fluid systems design life! :)
Dougster
   / Sizing a Backhoe Thumb Cylinder #15
Dougster, what are the dimensions for the cylinder that you need? I may have a source.:)
Hi Brian - I seem to have misplaced my "cheat sheet" (all the dimensions I took a couple weeks back) and everything is folded up tight right now in the garage. I'll remeasure and PM you later today. :)
Dougster
dfkrug said:
I like welded cyls for this application and Surplus Center had some 3000psi 2x8 cyls for sale for only $45. I bought several. This is a slightly larger ID than my curl cyl, but the bkt curl will have more leverage thru most of its arc. I do not know the max pressure specs for my curl cyl. It is prob not stated for the Bradco either. I doubt they are the cheapo 2500psi cyls since the Bradco and my Prairie Dogs handle 2500psi wp by design. What is the 509's curl cyl OD?
Hi Dave - Should have answered this yesterday. The 509 uses a 3" bore, 2" rod hydraulic cylinder for the bucket. Cylinder wall thickness is either 5/16" or 11/32" as best I can determine it. OD measures exactly 3.70", but that includes paint thickness. Either way, the cylinder design pressure is well above the 2,500 PSIG published design pressure for the backhoe.
As a practical matter, I'll probably be limited to using a 3,000 PSIG welded cylinder for the thumb.
Dougster
   / Sizing a Backhoe Thumb Cylinder #18
Dougster
2" rod! That's huge.
Sizing the cyl for length was a tougher choice for me. A longer stroke
may allow the thumb to be retracted tighter against the dipper, while
still allowing useful range of motion. But longer stroke means a longer
cylinder so the pivot bracket on the dipper had to be farther up. Or...
I could use a shorter stroke and move the pivot position on the thumb
inboard. This gives less thumb leverage, yet the thumb has to be
stronger (longer moment arm). Lot of variables.
Here is a photo of a couple of the welded cyls I recently bought from
Surplus Cntr. I am quite happy with their quality. Photo is an unmodified
cyl and one that I shortened up for a tilt cyl for a T-n-T setup. I
substituted swivel eyes on each end.
dfkrug said:
2" rod! That's huge. Sizing the cyl for length was a tougher choice for me. A longer stroke may allow the thumb to be retracted tighter against the dipper, while still allowing useful range of motion. But longer stroke means a longer cylinder so the pivot bracket on the dipper had to be farther up. Or... I could use a shorter stroke and move the pivot position on the thumb inboard. This gives less thumb leverage, yet the thumb has to be
stronger (longer moment arm). Lot of variables. Here is a photo of a couple of the welded cyls I recently bought from Surplus Cntr. I am quite happy with their quality. Photo is an unmodified cyl and one that I shortened up for a tilt cyl for a T-n-T setup. I substituted swivel eyes on each end.
And who says size doesn't matter! ;) In terms of cylinder length, I must stick with what Bradco has already designed and left me. :) I sent these cylinder specs to Brian, but I may as well post them here as I am having difficulty finding a close match:
Bore: 2.75"
Minimum Rod Diameter: 1.50"
Minimum Pressure Rating: 3,000 PSIG
Maximum Closed Pin-to-Pin Length: 26.0"
Minimum Closed Pin-to-Pin Length: 24.5"
(Ideal Closed Pin-to-Pin Length: ~25.0 to ~25.5")
Base End Fitting: Tang, 1-1/4" pin, 1" wide
Rod End Fittiing: Crosstube, 1-1/4" Pin, 2" wide
Stroke: Whatever results from above!
Okay Folks... anyone know where I can buy this cylinder other than for megabucks through Bradco??? :eek:
Dougster
   / Sizing a Backhoe Thumb Cylinder #20
Dougster:
Try Item# 9-7336 from Surplus Center. $99.95 + shipping. You
will have to shorten it, but that is not bad. You can do the
cutting and take it to a welder and maybe get away for $100 for
the welds. SC has other choices, too. 2.75" bore will limit your
choices somewhat.
I never find exactly the size of cyl I want. I either design around
what I buy or modify it to suit.
2006 CHEVROLET EXPRESS SERVICE VAN (A59904)
2006 CHEVROLET...
CASE 610 Sprayer System 2000 Gallons (A61307)
CASE 610 Sprayer...
2013 Haulotte 4527A (A57148)
2013 Haulotte...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Peterbilt 579...
2020 DRAGON ESP...
