Skid shoes on a scrape blade
   / Skid shoes on a scrape blade #11
   / Skid shoes on a scrape blade #12
I do 2 things to help with your situation. First I turn the blade around so it arc's the opposite way. This keeps it from digging in. second, I have a manual 4-way blade that allows me to tip the blade left/right as well as angle it. I angle it at around 30 degrees but I just pull the other pin and allow the blade to follow the contours of the road. This eliminates any high pressure spots. Have no problem with pulling gravel now.
I do the same thing in regards to running the blade backwards so the curve is in the direction of travel. I have thought about going with the pipe on the cutting edge but I find that even though I normally plow backwards, I occasionally have to pull the blade and allow the cutting edge to dislodge ice and thick packed sections of crusty snow.
If I had the pipe over the edge there are many sections where the blade would simply ride up and skim over the hard packed snow.
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Wright Sentar (A50120)
2021 JOHN DEERE 648LB GRAPPLE SKIDDER (A52705)
2021 JOHN DEERE...
2018 JLG 20MVL ELECTRIC VERTICAL MANLIFT (A52705)
2018 JLG 20MVL...
KUOBTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUOBTA M6800...
2024 CATERPILLAR 242D3 SKID STEER (A52705)
2024 CATERPILLAR...
