Skid Steer - Tracks or Wheels?
   / Skid Steer - Tracks or Wheels? #21
What are the extra maintenance requirements and what sort of expenses are we talking about?
Sounds like tracks would be the way to go for what I want. Maybe I should rent one for a day and see how it goes. However not having any experience with one I may not be able to learn much in a day.
I read a fairly good analysis on the cost to operate a CTL over time. Basically, it's fairly cheap until the first track replacement (~1200-1500 hours) Not too bad up to the second track change (~600 hours later for aftermarket tracks) but then you start getting into idlers, sprockets and finally drive motors. My take away is that 2000 hours is the point at which I'll replace my machine. For the average small, non-commercial user, like we find on TBN, that could be 10 years or so.
I believe that analysis was over on heavyequipmentforums.
   / Skid Steer - Tracks or Wheels? #23
Since I run tracks my vote is tracks. Besides I had no choice wheels don't work in the beach style sand I have on my land. The tracks FLOAT over the sand, mud etc.
I have a 287B and I can honestly say it's the best piece of equipment I've owned. I'm sure other track machines are as god, but I don't know. I bought CAR because of the service available to me. I call them up and a few days later a huge service truck shows up, changes all the fluids, filters and adjusts the tracks as needed. Anything you look at make sure you get proper support in regards to service, that's more important than the LOGO on the machine.
   / Skid Steer - Tracks or Wheels? #24
we had 2 different skid steers work for us at about the same time; we didn't own either one. The soil was quality topsoil with some very moderate grades. It was obvious that the tracked machine performed circles around the wheeled one, especially if there was some moisture in the ground; the wheeled one frequently lost traction and became ineffective, the track one was an eveready bunny .
I'll be buying used and that concerns me. Especially since I don't know what to look for. Maybe I better stick to wheels. My neighbor had an old one with wheels and loves it. His land is similar to mine and if wheels work on his property they should on mine too. However I think the tracks would be better.
My take is that it depends a lot on the surfaces on which you operate. If wheels don't get it at times, consider Track Over Tire. OTT Tracks | Over The Tire, Rubber, Steel | Tracks and Tires
Maybe that's the compromise that would work for me.
   / Skid Steer - Tracks or Wheels? #26
Bobcat magazine suggests figuring 8 dollars a hour for billing to replace your tracks when due. That is Bobcat telling you it is not going to be cheap.
   / Skid Steer - Tracks or Wheels? #27
This is mine,in 500 hours I went through the original tires and was 1/2 way through the second set. It think tires wear quickly because they spin instead of getting traction. These have been on for about 150 hours with minimal wear showing, other than some small cuts from rocks.
   / Skid Steer - Tracks or Wheels? #28
Hilbilly, try to rent each style of machines, it will be hard to rent one with OTT's though. Your "right" choice is as individual as anything else you might buy. Your soils, topography, and tasks will dictate what machine will suit you best. It doesn't sound like you have a need to run it on the lawn, that's kinda just crazy anyway with any SS/CTL with the possible exception of Bobcat's "A" series (all wheel steer). I find that in the woods, OTT's provide the best traction, but they will literally shred the surface that you are operating on. (hence traction). You'll learn to "mop" your way out backwards if you want to clean up machine tracks. CTL's obviously provide the best flotation & better traction than a wheeled (only) machine, but the wheeled machines have their application's also along with lower operating costs. If you ever need to operate on packed snow & ice (move snow), being able to put tire chains on your machine keeps your machine working for you during the winter instead of sitting in the shed. I have an excavator and a SS for similar use's as your's, and they sure do compliment each other and make a good team. Lot's to think about!
   / Skid Steer - Tracks or Wheels? #29
I would look into a MTL undercarriage. Multi Terrian Loader. Cat makes a few different models, not sure of your price range but everything from the 247-297 are good machines, mine the 257. Very tippy, but the rest are fine.
That's nuts. 1000 hrs and an $8000 cost for tracks. I'll stick to wheels and or OTT's.
I have a 75 series excavator and have been using it quite bit lately to open up the bush around our house and make some more trails for the grandkids to ride on. The excavator has a QC system, dig bucket, clean up bucket and push blade (very nice for leveling). It works great but still need to use another machine to grab piles of debris and move to the burn pile, smoothing and raking after the rough grading and mowing the small brush where the ground has not been disturbed too much. I've been using the tractor for this but it is not well suited to being in the bush. Last year I tore out a cooling line and this year I've had some close calls with branches getting caught in the hydraulic lines and undercarriage. It's also scary on side hills, especially where there are hidden potholes. I don't do this sort of thing often but it sure is nice to have the equipment when there is a need. If I get one I plan to spend between $10,000 and $20,000 and it's hard to justify spending that one something that won't get used a lot. But then I only have 550 hrs on my 6 yr old tractor and wouldn't be without it.
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
Kubota T1700X OHV Riding Mower (A57453)
Kubota T1700X OHV...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A56858)
2017 Ford F-550...
Unused SDLWC Wood Chipper (A55272)
Unused SDLWC Wood...
2023 Chevrolet Tahoe FL SUV (A56859)
2023 Chevrolet...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
