Skidding firewood logs?
   / Skidding firewood logs? #31
Got a small tractor. Nead the weight for traction. Got the bucket full of rocks too.
Egon
winchman
Appreciate your comments along with the others. Look forward to pictures of the attachment you made.
penokee /forums/images/graemlins/smile.gif
   / Skidding firewood logs? #34
IMHO, if you intend to use the tractors 3-point lift to lift the log I would not use cable chokers. You will not be able to get a short enough hook-up to utilize the tractors full range of lift. Cable chokers are fine for actual log skidders and 3-point mounted logging winches because a short hook-up is not that critical. I also find that chain chokers are easier to store on the tractor when you are going back for your next pull. I use what I'll call a "poor man's choker" which consists of a 6' to 7' piece of chain with a slip-hook on one end, easily purchased at any hardware store. A better way to make them up would be to buy square link chain and an actual choker slip-hook sold by logging suppliers. The square link chain will dig into the log better and will have less chance of slipping off. Well, that is my plug for chain chokers for your intended use. They would be better from my past experiences.
winchman
winchman
Thanks for the info. Plan to look into the chain chokers. I Use the cable chokers to skid logs with my AC H3 crawler, guess I never really thought it thru about lifting/skidding with my L3130. Got more homework to do.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
2022 New Holland T5.120 Tractor with Loader (A51573)
2022 New Holland...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
New/Unused Agrotk Horizontal Band Sawmill (A51573)
New/Unused Agrotk...
