Slime in a dump trailer tire?
   / Slime in a dump trailer tire? #11
Reg said:
Except that several of the tire sealant web sites claim that the sealant actually balances the tires dynamically/automatically as it gets distributed around the inside of the tire.
I had thought that the "except trailer tires" clause was partly because the load rating of trailer tires is at a top speed of 65 MPH - - not that 90 with trailers is uncommon around HERE (-:
Ok, I'm curious. What tire sealants state they actually balance the tire? I can't say I have ever seen any. :) I know the one I sell clearly states in the product literature that it is for use with speeds up to 45 MPH.
Quoted from the spec sheet. Tire Seal
"The uses of TIRESEAL® are as varied as the many different types of equipment to be found, from the largest of earth-moving equipment tires, to farm tractor tires and even golf cart tires. Its intended for use in slow moving, off-road tires. This product is not to be used in tires which are installed on vehicles utilized for over-the-road service at speeds exceeding 45 miles per hour. Any product inside a tire could cause an imbalance problem at high speeds. Also, the sealing ability of this product could be impaired by high speeds. Speed will create a centrifuge effect, which could hinder the sealing ability in a tire."
2018 JCB 3TS-8T Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50775)
2018 JCB 3TS-8T...
KJ 7'x20' Metal Farm Driveway Gate (A53316)
KJ 7'x20' Metal...
2016 HINO 338 26FT BOX TRUCK (A56129)
2016 HINO 338 26FT...
2016 Ford Escape SUV (A55758)
2016 Ford Escape...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2022 Third Coast Reversible Plate Compactor (A54865)
2022 Third Coast...
