Slip clutch maintenance
   / Slip clutch maintenance #11
If outdoors/exposed, perhaps just remove the shaft/clutch between uses, and store it inside till you need it next.
//greg//
Well slap me stupid! Why didn't I think of such an obvious solution? :ashamed:
Joe
Got the drive shaft off and put inside.. WOW-- one of the grease zerks had almost unscrewed all the way- just hanging on with one or two threads. Pretty lucky.. :D.. -- I will loosen the springs and slip both cluthes this spring-Just wish I had thought of taken the shaft off earlier this year and stored them inside... The tiller shaft is a binacchi but cant find out what the cuttery shaft is--it is a Big Bee 5FT rottary cutter any ideas???
AndyG
   / Slip clutch maintenance #13
My driveshafts come off and live indoors during the winter months, and the front halves come in after each use. I took the Eurocardan slip clutch apart and cleaned it up this fall before storing it, took about an hour.
Sean
10 Snow Plow W/ Bracket (A47477)
10 Snow Plow W/...
6x16 4 Wheel Wagon (A53316)
6x16 4 Wheel Wagon...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2015 Ford Explorer AWD SUV (A55758)
2015 Ford Explorer...
1995 Ford L-9000 Aeromax (A53314)
1995 Ford L-9000...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A56129)
2012 FREIGHTLINER...
