Slip clutch needed for rototiller ?
   / Slip clutch needed for rototiller ? #1
Alan0043
Bronze Member
Northeast Ohio
NH TC24D
I need help with advice. I am in the planning stages of prepping my land for grass seed. I have read the different post here on TBN. There is one common thing that I have seen, it is to protect your equipment and tractor. What is the best way to protect your tiller and tractor ? I do not see a shear bolt on the tiller. Is there one way better than another way ? I want to get the best protection for the the tractor and tiller. Is an over running coupler better than a slip clutch ? Where is the best place to buy either ? What would the cost be ? What is the best size ? I have a NH TC 24 tractor.
Thank you for any and all help.
   / Slip clutch needed for rototiller ? #2
Alan,
If you can't locate a shear bolt on the tiller and you want protection, go for the slip clutch. I really don't think an over running clutch will do you any good in this case.
Jerry
   / Slip clutch needed for rototiller ? #3
Alan I have seen slip clutches at TSC but I don't remember the price on them. I have one on my KingKutter tiller and it works well when I encounter a large stone.
   / Slip clutch needed for rototiller ? #4
ALL CCM Gear Drive tillers come with a clutch. An over running coupler is needed only when cutters are used. Many of the newer tractors have the over-run protection built into the PTO systems, likely your TC24 have it built into it. The over-run coupler only protects the tractor from the transference of the inertia of the implement to the tractor via the PTO.
   / Slip clutch needed for rototiller ? #5
</font><font color="blue" class="small">( I have seen slip clutches at TSC but I don't remember the price on them. )</font>
A slip clutch at TSC runs around $95.
Do slip clutches come in different sizes or is it one size fits all ? Does any of the TBNers sell slip clutches ?
Thanks again,
   / Slip clutch needed for rototiller ? #8
I think that there is defintely some type of system on the tiller. Is it belt drive?
Art, I think it is chain driven. The rototiller is an Yanmar model # 1503. I think it is a grey market tiller.
Ron, Thank you for the help. Can you tell me what the part number should be. I can not tell what would be the correct slip clutch. Seems a little confusing to me, to many choices.
   / Slip clutch needed for rototiller ? #10
Alan0043
This is the PTO clutch that they have listed in their cataloge.
32323 EA 18 1356242SLIP CLUTCH W/1 3/8SMF M X1 3/8SMOOTH FE $62.49
To order you will have to call. If you have the shaft size they should be able to fit a clutch to your tiller.
If you get a clutch make sure that shaft is not to long. Your tractor and tiller can be damaged by PTO shaft being to long.
Here is a link on problems with a PTO Shaft that is to long. Click Here
Brent 1082 Auger Wagon (A59814)
Brent 1082 Auger...
gps trailers (A56859)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
