Slip clutch needed for rototiller ?
   / Slip clutch needed for rototiller ? #1
Alan0043
Northeast Ohio
NH TC24D
I need help with advice. I am in the planning stages of prepping my land for grass seed. I have read the different post here on TBN. There is one common thing that I have seen, it is to protect your equipment and tractor. What is the best way to protect your tiller and tractor ? I do not see a shear bolt on the tiller. Is there one way better than another way ? I want to get the best protection for the the tractor and tiller. Is an over running coupler better than a slip clutch ? Where is the best place to buy either ? What would the cost be ? What is the best size ? I have a NH TC 24 tractor.
Thank you for any and all help.
   / Slip clutch needed for rototiller ? #2
Alan,
If you can't locate a shear bolt on the tiller and you want protection, go for the slip clutch. I really don't think an over running clutch will do you any good in this case.
Jerry
   / Slip clutch needed for rototiller ? #3
Alan I have seen slip clutches at TSC but I don't remember the price on them. I have one on my KingKutter tiller and it works well when I encounter a large stone.
   / Slip clutch needed for rototiller ? #4
ALL CCM Gear Drive tillers come with a clutch. An over running coupler is needed only when cutters are used. Many of the newer tractors have the over-run protection built into the PTO systems, likely your TC24 have it built into it. The over-run coupler only protects the tractor from the transference of the inertia of the implement to the tractor via the PTO.
   / Slip clutch needed for rototiller ? #5
</font><font color="blue" class="small">( I have seen slip clutches at TSC but I don't remember the price on them. )</font>
A slip clutch at TSC runs around $95.
Do slip clutches come in different sizes or is it one size fits all ? Does any of the TBNers sell slip clutches ?
Thanks again,
   / Slip clutch needed for rototiller ? #8
I think that there is defintely some type of system on the tiller. Is it belt drive?
Art, I think it is chain driven. The rototiller is an Yanmar model # 1503. I think it is a grey market tiller.
Ron, Thank you for the help. Can you tell me what the part number should be. I can not tell what would be the correct slip clutch. Seems a little confusing to me, to many choices.
   / Slip clutch needed for rototiller ? #10
Alan0043
This is the PTO clutch that they have listed in their cataloge.
32323 EA 18 1356242SLIP CLUTCH W/1 3/8SMF M X1 3/8SMOOTH FE $62.49
To order you will have to call. If you have the shaft size they should be able to fit a clutch to your tiller.
If you get a clutch make sure that shaft is not to long. Your tractor and tiller can be damaged by PTO shaft being to long.
Here is a link on problems with a PTO Shaft that is to long. Click Here
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
2018 KOMATSU WA270-8 WHEEL LOADER (A60429)
2018 KOMATSU...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
