Slip Scoop
   / Slip Scoop #11
hi dave,
don't know were you are in maine, but i was up to eddie nash's place in colebrook nh and he had a couple of scoops
i bought a tiller and post hole digger from him[ her, his daughter] and found the prices to be very good the number up there is 603-237-8857, its worth the trip just to look around the guy yard must be 5 acres of machine of all types there
chris smith
porter maine /forums/images/graemlins/smile.gif
   / Slip Scoop
Chris,
I think I drove past there on a recent trip to Montreal. It's a bit of a hike but might be worth a look. I'll give them a call. Thanks for the info.
I'm over in Vassalboro.
David
   / Slip Scoop #13
You might ask you dealer, if he can get one. Most dealers don't carry every implement in stock, from every supplier that services them.
   / Slip Scoop
You're correct about dealers not being able to carry everything. Especially such a small item that is not a big seller. However when I called the NH dealer, where I bought my tractor, the person I spoke with said he had never heard of a slip scoop, rear scoop, 3 point hitch scoop or pond scoop. He did not offer to find one or ask someone else about the scoop. Was it because I only want to spend $200 and not $20,000? I hope not.
   / Slip Scoop
I found a local dealer who sent me to his local supplier/warehouse. Picked up the scoop yesterday. It is sold under the name Worksaver S-1030. It looks like the Howes 30". I started making the modifications pretty much the same ones made by and discussed in past TBN posts. The experience of others really helped me. I first cut the front corners so the lift arms wouldn't hit. Then I filed the lever catch arm thing. Next will come the heavy spring to assist with the dump release when the weight is in the front of the scoop and a release arm extension to replace the rope.
Although the scoop works fine and I moved a few yards of loam last night it might not be able to keep up with Schooner, my Bernese Mountain Dog, who take the dirt out of the holes faster than I can fill them.
Thanks again for the wisdom.
David
2017 Liebherr L566 X Power Wheel Loader, PIN# VATZ1484EZB044020, Liebherr Turbo Diesel Engine, Cr... (A59076)
2017 Liebherr L566...
2019 Ford F-550 Altec AT41S 40ft. Bucket Truck (A55973)
2019 Ford F-550...
2012 PROCO 130 BBL VACUUM TANK TRAILER (A58214)
2012 PROCO 130 BBL...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
2013 HYUNDAI Veloster (A56859)
2013 HYUNDAI...
