Slow Leak of Filled Tire
   / Slow Leak of Filled Tire #1
Dennisfly
Lake Anna, Virginia and Alleghany County, VA
John Deere 4410
I have a JD 4410 with a slow leak in the left rear tire that needs to be aired up every week and a half or two. It is a tubeless turf tire that's filled and I see no fluid leaking. I replaced the valve core and it made no difference. The tire/wheel weighs over 700 Lbs so I don't want to take it off to try and submerge. Running water over the outside shows nothing. Should I drain it and take it to a tire shop or are there other better ideas?
   / Slow Leak of Filled Tire #2
I had a similar issue but on a front tire.
I didn’t remove the tire. I sprayed Windex on the tire. The slow leak - very small thorn - showed itself by bubbling. I think the Windex tends to show the bubbles better than plain water.
It took me a while to find but, if air is leaking out the tread, it will eventually bubble.
Good luck.
MoKelly
   / Slow Leak of Filled Tire #3
Simple solution is go to your JD dealer and get some of their tire sealant for liquid filled tires. That stuff is amazing and will seal off any small leak. I have used it on multiple tires in the past with no more flats.
   / Slow Leak of Filled Tire #4
If you simply want to find the leak try a solution of liquid dishwashing detergent and water.
   / Slow Leak of Filled Tire #6
All good ideas. I didn't know there was such a thing as a filled tire sealant. That's what is great about this site!
That stuff replaces 10% of your tire fill. If you have 50gal. fill in each tire, that's ~$170 per tire. o_O
MULTI SEAL HYDRO 1500
   / Slow Leak of Filled Tire #7
That is not the stuff I am talking about. The JD stuff will work and it takes a lot less. It is not that expensive. Maybe $50 at the most. Most JD dealers carry it and if not they will order it. The only sealant I will use.
   / Slow Leak of Filled Tire #8
Got a name for it? That Multi Seal / Flatout stuff is *amazing* as well, but if I can get it cheaper and it will last in the tire just as long...
   / Slow Leak of Filled Tire #9
It is called John Deere Tire Sealant. They have one version for air and one for liquid.
   / Slow Leak of Filled Tire #10
Thanks.. I'll probably try some. The Flatout stuff works for 1/2" officially and I had it seal larger. Sealed one tire with just over 1/4" hole in one revolution and that one already had Slime (crap stuff).
Mini Excavator Attachment Set (A50121)
Mini Excavator...
2014 Nissan NV200 Cargo Van (A50323)
2014 Nissan NV200...
2 Basket Hay Tedder (A50515)
2 Basket Hay...
New Valley Pioneer SCL850 Mini Skidloader (A50774)
New Valley Pioneer...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
Wolverine Quick Attach Rock Rake (A50515)
Wolverine Quick...
