Sludge in Rotella T5
/ Sludge in Rotella T5 #1
davesl708
Elite Member
Shawnee, KS, USA
Kubota BX2200D,
I just changed the engine oil after 100 hrs. I used Rotella T5. I found clumps of sludge in the drain pan afterwards.
I use Kubota filters. The tractor has 1380hrs on it.
Has anyone found this in their oil? I have not found sludge before using other oils in any of my equipment or vehicles.
/ Sludge in Rotella T5 #2
I've used T6 more than T5, but I've never had that issue. Although, the T5 I used was a (edit - "full" synthetic) version that I don't think was available in the USA.
Rotella in general is usually pretty good, in terms of detergent levels - what oil did you use previously ?
What time span (months) did that 100 hours cover ? Is that the factory change interval for your tractor ?
Rgds, D.
I am currently running T6 in it.
The T5 I used was synthetic blend.
I used T5 since I bought the tractor five years ago. This is my third oil change. The OEM recommends 200hr change but I changed it at 100hrs. It was in for about one year.
/ Sludge in Rotella T5 #4
have you been in charge of oil change intervals on those 1300 hrs? come w/a service record? oil may just be doing it's job on a neglected engine, perhaps dangerously so? if it's breaking up sludge, may want to change more often. or could this just be moisture buildup? just a thought best regards
have you been in charge of oil change intervals on those 1300 hrs? come w/a service record? oil may just be doing it's job on a neglected engine, perhaps dangerously so? if it's breaking up sludge, may want to change more often as it breaks up. or could this just be moisture buildup? just a thought best regards
I bought the tractor with 1170hrs on it. I do not know what the service was before I got it. I do know it was due when I got it and the trans/hyd. fluid was in bad shape.
The tractor is stored in an unheated garage.
/ Sludge in Rotella T5 #6
ok, think the T6 move was a good one. so.....in 5 yrs, you've added 200 hrs? lots of cold short runs? personally would change oil annually regardless of hrs or whether using syn. or dino. moisture buildup & previously neglected oil changes could be the culprit. bet you'll be ok once it levels out.
/ Sludge in Rotella T5 #7
I'm with bb - probably just the T5 doing it's job on old deposits. Easy to spend somebody else's money..... that said, I'd probably change it at 50 hours next time - at a minimum I'd sample the oil for analysis, to see if anything major shows up in testing.
Plenty of people (I'm one) get great service from T6.
Rgds, D.
/ Sludge in Rotella T5 #8
Rgds, D.
dido. maybe change semi annually or every 50 hrs till it clears out. & hi quality filters.... :)
I think I will get an analysis on the oil. I use OEM filters and the original owner did too. Just don't think he did it timely.
When I had the valve cover off for valve adjustment the top was clean with no build up or lacquer.
Thanks for the input.
/ Sludge in Rotella T5 #10
you're probably right and wise choice on your move.
/ Sludge in Rotella T5 #11
Make sure your engine is operating with a working thermostat. Engine running too cool especially one that makes lots of cold starts with short work time.
Thermostat was change 200hrs back. Usually starts and operates for an hour or more each time.
/ Sludge in Rotella T5 #13
I use t5 , no issue on oil.
/ Sludge in Rotella T5 #14
The top end being clean is a good sign, and the oil analysis isn't a bad idea at all. This is why I like to do an engine oil/filter change immediately with any used machine, run it for maybe 20 hours, then do another oil/filter change....hopefully that gets any old deposits out.
This is why I am perplexed. The engine has had three oil changes in 210hrs. This is the first sludge I have seen. Maybe just took awhile to break loose.
I cut the filter open and no sign of metal or plugging of the filter media.
Next oil change will get sent in for analysis.
/ Sludge in Rotella T5 #16
On a new to me machine that isn't going to be an immediate teardown, I do a full service, then after working it, and on it a bit, another change. You never know what the prev owner put in or how they used it. I've bought working antiques, that I'm guessing still had antique oil in them that maybee got topped off as it got low, including finding vintage OEM filters stacked solid...
/ Sludge in Rotella T5 #17
I'd bet your idea that it took a while to break loose is most likely. Since the filter and the top end all looked good, I wouldn't be too worried, but it's certainly worth doing the analysis to be sure. Still, it does make you wonder how other people take care of their machines!
/ Sludge in Rotella T5 #18
might also during engine operation keep a close eye on oil pressure gauge on the small chance something broken loose has not restricted oil flow. bet you're fine though
2018 International WorkStar 7400 Lely 4,500 Gallon T/A Septic Wet Vacuum Truck (A59230)
2018 International...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
43018CFL (A59228)
43018CFL (A59228)
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
