Small (10' x 12') pole barn-does this look sturdy enough?
   / Small (10' x 12') pole barn-does this look sturdy enough? #12
I need a shed for my yard equipment as well as a new woodshed. The old pallet shed is probably about to see it's last winter. I looked at the DIY kit sheds at Lowes and they want $2000 for a 10 x 12 shed with 7' high walls and a gambrel roof:
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=343541"/>
I stepped inside one at the local store and they're well built-2x4 construction throughout, nice high ceiling with plenty of loft space, etc...but I thought I might be able to do better. I kept the 10 x 12 footprint and I came up with a pole barn type design using 4 x 4 x 10 treated posts (2' in the ground, 8' above ground), 2 x 6s as the purlins, and 2x4 trusses with OSB scab plates copied directly from the Lowes shed down to the angles. In addition to the shed of course, I also need wood storage, which I plan to put on either side via simple lean-tos. Here's my design:
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=343542"/>
As you can see the design is very spare using as little lumber as possible while (hopefully) maintaining a strong structure. The posts will be set about 2'-6" deep. At the bottom of each hole will be a concrete paver to form a footing, and about 4" of gravel for drainage. After the post is set and leveled, two 80 lb bags of dry concrete will be poured in around the hole and tamped, and dirt will be shoveled in and tamped to grade level on top of that. I didn't draw all of the trusses or rafters because it would have taken too long, but they will both be spaced 16" OC since this is the Northeast and they will most certainly see snow loads. The 2x6 girt board at grade will serve as a "form" of sorts as I will be filling in the floor area with what is locally referred to as "crusher run" (basically small stone chips mixed with stone dust) which will be wetted and tamped-a poor man's concrete slab. The whole thing will be sheathed in 7/16" OSB except for the front and back walls which will be sheathed in "Smart Side" which an OSB product with a finished face that looks like T-111:
SmartSide 96 in. Composite Panel-27874 at The Home Depot
The side walls will just be covered in tar paper since they won't be seen unless the woodsheds are empty. The roof will get tar paper and whatever shingles I can get a good deal on the week that the roof goes on. The door will come from here and will be the single most expensive part of the shed, but worth it IMHO:
Roll Up Door Depot | High Quality, Durable, Worry-Free Steel Roll-Up Doors | Security Door, Storage Door, Metal Roll Up Door for Garage, Shed, Commercial, Industrial & Agriculture, 866-727-1184
No worrying about sagging hinged doors, etc... I figure I can put it all together for about $1500, so I'm coming in at $500 less than what Lowes is charging, plus with 8' walls I should have about 1' of additional loft headroom, which will come in handy because part of the purpose of the shed will be to clear the seasonal decorations out of the garage. I just want to be sure that 4 x 4 x 10 posts spaced 6' OC and 5' OC will be adequately strong. 6 x 6 x 10 posts would add about $175 to the total cost-is it worth it/necessary?
Any photos of your pallet shed? I am thinking of throwing one together for wood storage.
   / Small (10' x 12') pole barn-does this look sturdy enough? #13
My suggestion is that if you think a 10x12 is big enough, you should add at least 2 foot on each side as a minimum. They fill up faster than you think. I built a 30x30 with 12 foot wings on each side and 2 years later added a 14x30 enclosed wing to the back for additional storage and it is crammed full now and all my tractor equipment and trailer is still outside. Amazing how fast "stuff" accumulates and you need a place to put the seldom used but vital accessories.
If you build it,, junk will come.. I have a 50' x 54' with ten foot ceiling.. also I have a 20' x 32' metal on slab.. both are full and my equipment sets outside under tarps.. Lou
Built entirely from pallets and $30 worth of lumber from the junk pile at Lowes... It was about 16' x 8' and held about 5 cords of wood, but as I said, it's kind of falling apart, but it served it's purpose for five years. It's time for something that will last.
   / Small (10' x 12') pole barn-does this look sturdy enough? #15
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=343603"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=343604"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=343605"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=343606"/>
This is freakin sweet!!!! I happen to just get a shipment of pallets
from a buddy and am looking for ideas.... This looks like the Taj Mahal !!!!
   / Small (10' x 12') pole barn-does this look sturdy enough? #16
I didn't know they sold ten foot treated 4x4 posts, but the cost for 12 foot ones can't be very much more. Why not get the longer posts and put them three feet down and have nine foot walls, or stick with two feet and a couple sacks of concrete with ten foot walls?
The gambrel roof gives you a little more storage area, but with the lean too next to it, you will have problems with leaves building up there. Then it's either a never ending job of cleaning them off or letting them rot and creating a wet area that will lead to issues in the future. You also mentioned snow. That is where it will build up and lead to problems. A straight, smooth roof is going to save you a lot of headaches in the future.
Eddie
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
2005 EAST 45' WALKING FLOOR TRAILER (A54756)
2005 EAST 45'...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56435)
2023 Kubota...
cummins generator (A56857)
cummins generator...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
