small carb neelde jets
/ small carb neelde jets #1
jaotguy
Veteran Member
Ottawa, Ont
Ariens
OK this is for all you plating guys out there
Almost all small engine carbs today suffer from the dreaded ethanol.
I'm tired of pulling the idle needle jets out of my carbs every couple of weeks, giving them a brass brush "rub" to remove the rust and gunk, a quick spray of carb cleaner and putting them back in just to get the machines to run correctly again.
Things I've tried : Only high test gas , keeping the tank topped up, running the carbs dry before putting them away till the next time they are needed , fuel stabilizer ... it all helps a bit but the problem returns
Is there some EASY way to plate the jets so they don't rust? Or am I doomed to get stainless screws ( or nylon, etc ) , break out the lathe and turn new needle jets myself?
There are no plating shops left in town. Closest one is 200 Miles away and they won't handle a "small job".:(
I've done type 2 anodizing of aluminum , but I know it won't work on steel.
ANY suggestions?
2014 Komatsu HM400-3 Offroad (A62679)
2014 Komatsu...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2015 MACK CXU613 T/A 6X4 MID ROOF SLEEPER TRUCK TRACTOR (A59912)
2015 MACK CXU613...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2016 VOLVO EC250EL EXCAVATOR (A62129)
2016 VOLVO EC250EL...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
