Small square bales in wagons
   / Small square bales in wagons #11
I'll guess it at 8x18.
The OP isn't going to get 4' bales through a thrower or kicker, doesn't matter which. 32-36" is about the limit.
Yeah, 4 ft isn't going to happen. That will be obvious after the first couple bales.
Actually, he should size the bale to fit the wagon. If it's 16 ft long he can make them a little longer and still fit five on the floor. At 18 ft he could make them a whisker shorter and fit 6 in line on the floor.
   / Small square bales in wagons #12
I would add that make your you have a front gate on the wagon, It will help to add a couple more bales between changing out wagons. It also keeps the hay from sliding out the front when going down hill! :thumbsup: (ITs prolly common sense but I figured I'd add it.)
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
Takeuchi TB016 (A53317)
Takeuchi TB016...
2021 Kubota SVL75-2 Track Loader (A55315)
2021 Kubota...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
