Small square bales in wagons
   / Small square bales in wagons #11
I'll guess it at 8x18.
The OP isn't going to get 4' bales through a thrower or kicker, doesn't matter which. 32-36" is about the limit.
Yeah, 4 ft isn't going to happen. That will be obvious after the first couple bales.
Actually, he should size the bale to fit the wagon. If it's 16 ft long he can make them a little longer and still fit five on the floor. At 18 ft he could make them a whisker shorter and fit 6 in line on the floor.
   / Small square bales in wagons #12
I would add that make your you have a front gate on the wagon, It will help to add a couple more bales between changing out wagons. It also keeps the hay from sliding out the front when going down hill! :thumbsup: (ITs prolly common sense but I figured I'd add it.)
Case 1020 25ft Draper Head (A55315)
Case 1020 25ft...
2020 DRAGON ESP...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
404 (A52706)
404 (A52706)
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
