Small storage tank?
/ Small storage tank? #1
Slippy
Veteran Member
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
Read a lot about cons of storing fuel. Has anyone seen a say 20 to 30 gallon storage tank that has a pump built in? Biggest problem with 5 gallon cans for me is lifting them up on top of the tractor and then not spilling it all over the place. Any ideas? I was going to get a 55 gallon drum and fill it about 1/2 and put hand pump on it, but a drum that size can be difficult to move from the truck to the floor, etc.
/ Small storage tank? #2
I have a 30 gallon poly barrel I plan to use for that purpose soon. I have a hand pump and as soon as I clean out the drum, I'll be putting it together.
Where would one find such a barrel. 30 gal sounds about right.
/ Small storage tank? #4
Todd makes a Diesel Caddy. Click Here
Checked EBay. There is one for $315 in Buy It Now. /forums/images/graemlins/blush.gif
My back is not that sore yet. /forums/images/graemlins/tongue.gif
/ Small storage tank? #5
Slippy,
In Columbus, there is a recycler of drums/barrels. Container Management Company near I-71 and 5th Ave. Cost me $26.00 +tax. I have the phone number if you'd like via PM.
Jerry: Thanks. They are on Corrugated Way and I got their number. Will call them tomorrow. Thanks again.
/ Small storage tank? #7
</font><font color="blue" class="small">( Read a lot about cons of storing fuel. Has anyone seen a say 20 to 30 gallon storage tank that has a pump built in? Biggest problem with 5 gallon cans for me is lifting them up on top of the tractor and then not spilling it all over the place. Any ideas? I was going to get a 55 gallon drum and fill it about 1/2 and put hand pump on it, but a drum that size can be difficult to move from the truck to the floor, etc. )</font>
I'd suggest about 100 gallon tank to be useful. You can use your FEL to hoist it full up to the top os a frame you'll build so that it can refuel all your diesel powered equipment via gravity flow. If you have a diesel truck and tractor, and maybe even a generator; you can supply all from one storage tank. You can get the stabilizer additive from marine stores if you think water and bateria are a problem.
Suitable tanks can sometimes be had from furnace supply stores, get one made to hold fuel oil, Furnace oil #2 and #2 diesel are the same thing, so all the fittings are fine.
Pat
I do have an old fuel oil tank. Will it work? Has been sitting for about 10 years. Best way to clean it out?
/ Small storage tank? #10
</font><font color="blue" class="small">( I have a 30 gallon poly barrel I plan to use for that purpose soon. I have a hand pump and as soon as I clean out the drum, I'll be putting it together. )</font>
I'm looking for a 12 15 18 or 20 gallon container.
/ Small storage tank? #11
I used a 35? gallon grease keg for mine. Grease was in a bag.. pulle dthe bag.. washed and wiped out with mineral spirits and a clean rag. Got a 19$ harbor freight rotary hand pump and a few feet of fuel rated hose, and a simple "L" shaped open nozzle end. Pump had the 2" bung adapter, and i used a 1$ small engine 'gas' filter plumbed via a short piece of hose to a 3/4" adapter to use as a 'vent' for the tank. Aranqed it in an upside down "J" so that the filter opening points down.
All this is on a cheap harbor freight hand cart with a bunji cord holding it on.
I painted the can 'diesel' yellow, and got a diesel plaque for it for a 1$ from the local fuel depot. ( fuel guy said that DOT -could- give you a hassle without the plaque, on a mobile 'tank'. though usually didn't bother farmers / non comercial people... i went the safe route and bought the 1$ sticker.. )
That way i can toss the rig on the trailer or in the back of the trrck and take it down to the station to fill up.
Soundguy
Picked up a poly 30 gallon barrell today for 25 bucks. Do I now have to paint it yellow and put a tag on it to get the bulk fuel put in it?
/ Small storage tank? #13
</font><font color="blue" class="small">( Picked up a poly 30 gallon barrell today for 25 bucks. Do I now have to paint it yellow and put a tag on it to get the bulk fuel put in it? )</font>
Don't quite understand your question.
Could you please clarify?
/ Small storage tank? #14
<font color="blue"> That way i can toss the rig on the trailer or in the back of the truck and take it down to the station to fill up.
==== </font> ====
Sorta like what I've got in mind.
A wheeled 12 to 20 Gal. tank I can throw in the bed of
my pick up and take it down to the station and fill it up.
The hand pump would mean good by to lifting and lugging 5 gallon cans.
For unloading the filled tank I plan to build a (dock, stand, shelf or what ever you want to call it) the same height as my lowered tail gate so I can just wheel the tank right off the truck onto the dock.
/ Small storage tank? #15
</font><font color="blue" class="small">( Do I now have to paint it yellow and put a tag on it to get the bulk fuel put in it? )</font>
The big truck stops and bulk fuel plant my company uses won't put fuel / allow you to put fuel, into an 'unapproved container'.. I'e'.. the local guy putting diesel in a gas can.. or gas in a milkjug to fuel his car stalled a mile down the road.. etc.
I chose to paint mine yellow to match the other diesel cans i see.. However i have seen trucks with plain aluminum tanks, white and black tanks get diesel.. no red tanks though.. and also.. all must have the diesel plaque on it AFAIK.. etc. Can't guess what the stations / fuel people in your area do.
Soundguy
/ Small storage tank? #16
<font color="blue">Suitable tanks can sometimes be had from furnace supply stores, get one made to hold fuel oil, Furnace oil #2 and #2 diesel are the same thing, so all the fittings are fine.
</font>
What different sizes do they come in?
I need something in the 12 to 20 Gallon range.
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
2022 Honda Ridgeline AWD Crew Cab Pickup Truck (A64556)
2022 Honda...
2013 Ford F-650 Ext. Cab Chipper Truck (A64194)
2013 Ford F-650...
2026 Electric Tricycle (A64194)
2026 Electric...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
