smaller backhoe bucket
   / smaller backhoe bucket #1
charlz
Elite Member
Meridian Idaho
Kubota B7100D
My Kubota b7100 came with a b670 which had a 16" bucket. I have a fair amount of sprinkler line to put in and I decided to make a smaller bucket. I read some of the posts on here concerning dirt sticking in the smaller buckets but we don't have clay so I think it will be OK. Also, I could just rent a trencher but what fun is that? ;)
I made templates from my original bucket, here are the materials, one bucket side already cut out:
I used the pieces for the 'ears' to help make the 90 angle that is at the back/bottom of the bucket.
Both sides now cut out, bottom bent, 'ears' made. I cut the sides with some Harbor Freight metal cut off wheels in my angle grinder. Worked pretty well and used about 1.5 of them :)
The original bucket and one pin had a wee bit of wear so I made a new pin. I thought about reworking the bucket to use collars on the ears and longer pins. I figured if this is what 30 years of use does the original design would probably work for me ;) The holes in the original bucket were out of round about 1/4 inch on one side, some quick work with the welder and they were close to new.
Everything tacked together for a test fit on the tractor. It fit perfectly.
A lot of welding later and some wishing for a MIG the bucket is now ready for bending/welding of the bottom.
I still need to get the cutting edge material and some teeth. Without those two items I have about $42 in materials which includes the new pin. I think I have spent about 8 hours on it so far. Mostly checking and rechecking the pin hole locations before drilling ;)
I'll post some pics after I finish it.
   / smaller backhoe bucket #2
Nice job!
A lot better than the last bucket I made, which was 42" wide for my boom mower. I just posted a picture from that. I used a piece of 1/2" flat bar for my cutting edge, cut at a 45 degree angle with a milling machine. I knew I wasn't going to be using it for digging but needed something to stiffen the long edge of the bucket. I figured a piece of 1/2 x 6 would stiffen up the edge, which it did.
How many teeth do you need, two or three? Does anyone make them that will adapt to your new bucket?
David from jax
   / smaller backhoe bucket #3
Excellent work! How about some dimensions, steel thickness, type. This looks like a good spring project for my electric lines. Craig
   / smaller backhoe bucket #4
Great idea,my last hoe had a 12" bucket and i can already see i'll miss it at times.My new hoe came standard with a 18" and i also was thinking about making a 12" out of some 1/4" steel.I have to study mine a little more as its a quick disconnect and i have to figure it all out first.I think with enough time and determination i can do it,whenever i run out of other stuff to do.
Looks good so far.Make sure you send those pictures in to show us your progress!!!!!What material did you make your new pin out of ??
digger2
   / smaller backhoe bucket #5
What a great project.
I love that you are doing it all from scratch like that. I bought a smaller bucket and it set me back over $600 bucks not including shipping! Not only that, but the bushing holes did not line up perfectly so I had to ream them out to fit. I should've made my own like you are doing.
The smaller 12" bucket made a big difference not only for narrower ditches, but also in the digging power. I use it when digging up trees and tearing through roots too.
   / smaller backhoe bucket #6
Indeed!! Great work! The narrow bucket will allow your hoe force to be more concentrated. What kind of soil do you have there? Sandy? A narrow buck sometimes also has problems with larger rocks, if that is on the menu. Great craftsmanship. Looking forward to seeing it dig.
Mike
Thanks for the comments! The new bucket will be about 9 inches from cutting edge to cutting edge. The bottom/inside is 8".
The original bucket is made out of surprisingly (I thought) light materials. The sides and bottom are 1/8 inch plate, the ears are 3/8 plate and for the angle bracket across the back I used 2x2 by 3/16. I couldn't find any references as to these parts being made out of anything other than mild steel so that is what I used. The cutting edge wraps around a little on the sides and ties the whole thing together.
I used a local place that is one of the Metal Supermarkets stores. They cut everything to the right length etc. with only one $5 shearing charge. Obviously your mileage will vary based on your particular hoe but here was my cut sheet:
(2) 1/8" plate 10"x14" (had to be sheared out of a sheet)
(2) 3"x3/8" bar 9" long (something was a little off with my measurements.. probably really needed 4"x3/8" but I made it work)
(1) 2"x2"x3/16 angle 5-1/2 inches long
(2) 2"x2"x3/16 angle 3/4" long
(1)1/8"x8"plate 25" long (need more like 24" but I wanted some room if my bend ended up wrong or I measured wrong... it's easy to cut off)
(1) 1"x7-3/8" 4130 round bar for the pin.
I still need to order the cutting edge which I think I will get from discountsteel.com and the bucket teeth. I am looking to put 3 teeth on it. I posted another thread looking for input on teeth. I think I can get what I need off ebay for a lot less than what Kubota wants for the teeth on the original bucket.
Charles
Mike
Our soil is mostly loam down to about 3' where there is a really hard old clay layer. Not many rocks, most are fist or double-fist sized with the largest well under head sized. That old clay layer is tough going with my 16" bucket and probably would be a lot easier with a smaller bucket. I don't need to go that deep though for what I want to use this bucket for (irrigation lines).
Charles
Had a chance to work on this some more today.
I thought I would give bar clamps a try to bend the bottom to fit. I drew a line on the inside of both sides as to where the top of the plate should be. On the big bucket the sides extend past the bottom about 1/4 inch. Sorry its at bit out of focus, didn't realize that until I downloaded the camera. The alternate method was going to be to mount the bucket on the hoe and then use the hydraulics to press it against the ground and bend the plate. With the clamps I didn't have to crawl around on the ground :)
Worked the clamps alternating sides... it was tough going sometimes. I tacked at little more than one inch intervals. When I got to the end I couldn't get it to bend in much. Looking at the big bucket I realized the end slowly tapered out until the bottom was flush with the edge of the sides. Makes sense as the cutting edge sits on both and is welded to them. Bending it in that much was easy.
Went back and slowly welded all the spots between the tacks.... Hard to weld inside the bucket but I did manage to duplicate some of the not-so-hot-looking welds on my original bucket ;) Notice the extra 1" of material I added to the bottom plate is there at the end... looks like I didn't need it after all. I will wait to cut it off until I have the cutting edge in hand.
Here is a pic of the new bucket next to the 16" I am using as a template.
Looks like I have better get on the stick and order the cutting edge and find some teeth!
Charles
   / smaller backhoe bucket #10
Great looking work. There are lots of places to get the teeth as well as the cutting edge. I have never priced lengths of cutting edge, but I wonder if using plow shares (~$14 or so for 16" length) would work.
   / smaller backhoe bucket #11
I'd try it without the teeth first. You may find that the narrower bucket likes to cut in on its own.
   / smaller backhoe bucket #12
I agree with trying it without teeth.
Now for the brainstorm that this project instigated...
If you are familiar with a cheese cutting tool, not the one with a wide roller and a wire for slicing cheese but the one narrow one without a roller. It is used to cut a narrow but thicker ribbon of cheese off a larger chunk. It is similar to the citrus tool used for cutting a long ribbon of citrus fruit peel off of a piece of citrus fruit.
Anyway it occurred to me that a narrow bucket with stout sides and an abbreviated back (mostly just a cutting edge and a mostly open back) might slice through material that would clog a regular bucket with a back on it. You should be able to get a nice thick and long piece of "peeling" sliced off with it on each pass.
Then to clean up the debris that might accumulate in the trench because of the "backless" bucket design, you bolt or pin on your removable back and use it to scoop out the debris left behind by the use of the bucket in open back mode.
The idea being to be able to dig in really hard or sticky clay and such without constantly plugging up the bucket and requiring manual intervention to clear the bucket.
Anyway there it is...
Pat
Pat
So basically a stirrup hoe for your back hoe? ;) I would imagine the stuff that gets stuck in your bucket would get stuck there even if it was already loosened up.
Charles
Well I ordered 3 feet of 3/8 x 3 cutting edge from discountsteel last night so..... ;) Almost as much in shipping as in steel. There is a steel place here that makes cutting edges... but they said 3/8 x 3 is too small for their machine :cool:
   / smaller backhoe bucket #15
Charlz,
One thing could have been done differently (too late now). On smaller buckets, the sides are flared out. That is wider at the top than at the bottom. That is done so the bucket will empty more easily. It's real hard to get some soils to pop out and smaller buckets seem to grip like a crazy thing. I've spent many an hour with the bucket upside down 6' in the air while I shovel at it until the soil comes out. Hopefully, that won't happen.
jb
   / smaller backhoe bucket #16
Draft. The sides of a mold, dirt bucket, or the partitions in an ice cube tray need DRAFT so the contents can more easily be gotten out.
What if there were a flap of steel shaped to nestle against the back of the bucket mounted on a hinge and hydraulically moved. When the contents of the bucket stuck you would activate this flap to eject the contents of the bucket. When digging it would be against the "REAL" back of the bucket so the flap wouldn't have to be as strong as the real back.
I think I read somewhere about having compressed air outlets that could be energized by a valve to help break loose the bucket contents. I think it was for muddy digging.
Pat
john_bud said:
Charlz,
jb
Yep, when I was reading old posts on here about building a backhoe bucket it seemed most people either wanted a really small one or a really big one. Couple people commented on the dirt sticking in smaller buckets. I figured I would just give it a go... pretty much the only way to find out ;)
This is only my second welding project since high school welding shop (20+ years), I built MadReferee's clamp on forks and trailer mover a month or two ago. Redesigning a backhoe bucket to incorporate taper might be stretching my skills :) Makes me wonder though...
Pat
But to do a hydraulic 'flapper' I would have to add a diverter valve or rear remotes... and if I did that I might as well build a hydraulic thumb as well... ;)
   / smaller backhoe bucket #19
Chas, Yeah, so? Don't you need a thumb??? Maybe a clever guy like you wold be able to incorporate a manual valve arrangement or a manual change to the cylinder mount to let one hydraulic circuit/cylinder be configured either as a flapper or as a thumb since you might not need them at the same time of for the same sort of tasks.
Pat
   / smaller backhoe bucket #20
patrick_g said:
Draft.
Pat
I have an 18" bucket on my backhoe that is just like that, but no hydraulic connection for the ejector flap - it works automatically when the bucket is opened fully. I'd go & take a picture, except its stuck in a shed down on my marsh & after 48hours of torrential rain is currently surrounded by 12" of water. If anybody thinks I'm putting waders on tonight they can think again! (besides I need the ducks to settle before I get at them on the weekend).
Its called an Ejector bucket,
"for continuous working in clay or very wet soils. an ejector bucket provides the most efficient way to remove a full bucket-load every time.
A mechanical paddle is moved into the back of the bucket as the bucket is crowded to allow a full bucket to be loaded. As the bucket is rolled back, the crowd link advances the paddle through the bucket, cleanly ejecting the contents."
Harford Manufacturing
2022 KAUFMAN 2 CAR TILT GOOSENECK TRAILER (A59905)
2022 KAUFMAN 2 CAR...
UNUSED AGT INDUSTRIAL STSD10 SEEDER (A60432)
UNUSED AGT...
2010 BOBCAT TOOLCAT 5610 UTILITY WORK MACHINE (A59823)
2010 BOBCAT...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2018 Keystone Outback Super-Lite 330RL T/A Travel Trailer (A59231)
2018 Keystone...
Ford 8510 (A53317)
Ford 8510 (A53317)
