Smart Meters
   / Smart Meters #41
Since it hasn't been answered yet..
So, smart meters are probably as safe as any other technology we use today in terms of EMF radiation. But will they work with your solar array? When the technology was first introduced, smart meters did not always work with solar panels.
Smart meters are basically computers, and they hadn’t been programmed to know what to do when electricity was fed back into the grid. Instead of “spinning” (of course, there’s no dial to actually spin) backward to give users energy credits, they kept going forward — twice as fast.
This led to disturbing moments as new solar homeowners promised lower electric bills got bills double the usual amount instead. That glitch, however, was fixed quickly with new programming, but not before rumors about smart meters’ incompatibility with solar arrays spread, further fueling people’s dislike of the devices.
Be aware: If you use solar energy, the smart meter issued to you should have a sticker reading “net” — this means the meter has been programmed to run backward and credit you in kilowatt hours for the electricity you feed back into the system.
With the new programming in “net” smart meters, not only do the smart meters work fine with a solar installation, but a solar PV array helps you make sure your meter is working smartly for you.
   / Smart Meters #42
they can simply shut off your power. They own the power lines, not you.
i have a smart meter oin my place for over 5 years, never have had a problem. i personally am glad they dont come on my property to read the meter anymore.
Thats what I just said - they can cut my power but they can't forcibly install a device I don't want. Why do they choose to do the latter?
   / Smart Meters #43
I was worried about that awhile back. Bought an arc welder and wondered if the cops and EC were going to accuse me of growing weed!!!
Didn't happen though.
Im curious with the welder did you actually see much of an increase that month? I have watched mine several years each time I do a project that takes alot of rods.(sometimes maybe 10 lbs worth) And have yet to see much of a spike in my bill.Even If there is,Its one of the most valuable cost savings 'appliance' a home can have. And the local utily here did a survey of usage and left a report that said I could save xxx a year and they recommended that I get rid of the welder.I can Imagine how much id spend farming it out..lol
Now i know these 30 minutes showers the two kids have twice a day add up. hmmm maybe they need to go lol lol
   / Smart Meters #44
What's the reason to control your HVAC? So you're in your home buying power at contract price and the company shuts it off? I just don't understand why they would want to do that or why anyone would agree to that.
It is popular here... many want to do their part and sign up for HVAC load shedding.
As to the meter itself. I had a tenant move. About a week later, I called to have the service turned back on in my name.
The utility said they can do electric remotely and I would have to be home for gas to be turned on.
   / Smart Meters #45
I had the AC cutoff switch two summers back. The program was supposed to give you half the AC time when energy demands were high. The way they figured it was to check your on time from 11 am to noon. Then they would give you 1/2 of that from noon to 6 pm. My house has many trees on the south side so our load is low in the morning. Also my house has a lot of thermal mass and takes time to heat up. Of course it is much cooler in the morning than late afternoon. So the 1/2 calculated time was actually much less than the needed 1/2 time. We had been out of the country and did not have personal experience with this, so I was going to leave it connected. As it turns out they did not reconnect the compressor high speed when they put in the box, so we had no AC at all when it was really hot. Anyway when the guy came out to fix the install he stated that they were disconnecting hundreds of these units every week. So I had mine disconnected. It sounds like their implementation was poorly thought out. I wish it had worked because it seems foolish to build more power plants.
   / Smart Meters #46
And of course that post #16 has a link to the "study" and the first paragraph should tell all you need to know. They didn't even have "smart meters" when that study started, but there are plenty of other electric and magnetic fields.
The study linked to in that post at HSM wasn't the pertinent part, it was this:
The next item is that the smart meter does not require a transmitter to do its job. In fact, both in the US and Canada the companies installing these meters cannot force you to accept a transmitter on your property. State or provincial law have no jurisdiction over RF devices, that is strictly a federal responsibility. In Canada, at least, there is no enabling legislation that can be used to force the installation of a transmitter on private property. The smart meter is perfectly capable of operating without it. It has an optical port on the front for a meter reader and it can also communicate via POTS (Plain Old Telephone Service). While they can mandate the installation of the meter they cannot mandate the installation of the transmitter.
   / Smart Meters #47
They did the same at my brothers... he had call the HVAC installer that was too busy to come out that day so I took a look.
The Utility had not connected the compressor!
Called to complain and was told the work was done by a third party and they no longer use that vendor.
   / Smart Meters #48
A day will come when you will not be able to buy a major appliance that does not have module in it that allows it to be controlled by the power company via the smart meter. There is no way they could dump this entire program on Joe Blow thus a phase-in over years. Water heaters I can see but don't mess with my AC during the summer.
   / Smart Meters #49
Here in Dallas they went with smart meters 2 years back, with a large solar system I watched it pretty close.
They gave some software & hooked us to their web sight. Not realizing what that led to, it was a bad surprise when they cut us off during one of their fake rolling brownouts.
After some cussing & **** raising.
TXU took us off of their list. With our system on grid when you have a power outage. You shut the solar system off.
   / Smart Meters #50
Being in Texas I don't believe I'd like my AC cut off for half the time between noon and 6. It might not ever catch up.
2005 TerraGator 8104 (A55301)
2005 TerraGator...
SCAN TO RECEIVE TEXT UPDATES (A54756)
SCAN TO RECEIVE...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A55787)
2020 Kubota Z723KH...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
30ft Highway Trailer Co. Lowboy (A55218)
30ft Highway...
