Smoking farmall a
   / Smoking farmall a #11
Parts for farmalls are reasonable. do the rings yourself and send the head out to get ground and have hardened seats installed the head might cost 300 at most and rings are around 50 put it back together and you’ll get 70 more years from it
   / Smoking farmall a #12
What if the spark plugs has a lot of both?
Dry with carbon build up, and black smoke ususlly indicates running to rich on fuel. If your plugs show carbon, plus oily residue, you're getting oil past the rings, or valve guides.
The standard plug was a Champion D15Y or equivelent. It was common to step up to a hotter plug to get by for a while, to a D21Y until the engine could be overhauled, or re-ringed at the very least. If left go long enough, and you tear the engine down, when pulling the pistons, you'll probably notice a similar buildup in, and around the oil rings, which only allows more oil to pass by them.
   / Smoking farmall a
Its smoking a lot less now, I'm not sure why. But anyways the plugs I use are Autolite 386's (its the plugs it had in them when i got it so i just bought the same ones) And the old ones had oil and carbon. If its the rings i hope to change them rather soon, thanks.
   / Smoking farmall a #14
A good upgrade would be to get rid of Autolite and get a good NKG plug. Never been a fan of Autolite.
   / Smoking farmall a #15
It probably set a while, and running it a lot will reseat the rings...
At least, THAT would be my first try...
SR
   / Smoking farmall a #17
The Motorcraft B82 is another great plug, if you can find them.
2020 CATERPILLAR 305E2 CR EXCAVATOR (A52705)
2020 CATERPILLAR...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
2010 Astec Underground RT660 4WD Trencher Backhoe (A55787)
2010 Astec...
2023 KOMATSU PC55MR-5 EXCAVATOR (A52705)
2023 KOMATSU...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
