Smoking Kohler CV20
   / Smoking Kohler CV20
CSAW, thanks for latest info.
I have not had the valve cover off yet,going there next.
Can't tell how the oil drains back to the crankcase from
the Service Manual,have e-mail into Kohler to find out.
Left side cyl is lower than the right side cyl.
Will let you know how it goes along. Charlie
   / Smoking Kohler CV20 #12
Talking to my nieghbor about his Scotts with a Kohler engine. I think it is a 20hp. Two and half years old and dropped the crankshaft out. Deere stood behind it and had a service bulletin out on it, but he found that out on his own and fought all the way to get a fresh engine.
Boone
On many OHV engines, a blown head gasket will cause
a severe smoking problem.
   / Smoking Kohler CV20 #14
Kohler had a problem with their head gaskets and their head bolts. Go to your local dealer, and they have a kit available that should take care of your problem. Pull the heads and make sure it hasn't caused any gouging in the cylinders first.
   / Smoking Kohler CV20 #16
Final report. Blown headgasket on # ! cyc.
Thanks for all the suggestions. Charlie
   / Smoking Kohler CV20 #17
Wow, great thread! I have a CV25 with similar problems. Blue smoke on start, blue smoke during acceleration uphill, blue smoke when I back out of the hydro petal for a couple seconds and re-apply. If it was a car engine, I would be thinking valve seals or guides. I bought the manual and was just starting to diagnose. My compression check is also OK. Power is great as well. Only three grasscutting seasons on motor (150 hours). Spark plug gets oil fouled on the passenger side cylinder. I will pull the valve cover and head and check stuff out.
Thanks for the info!
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A54607)
2023 MAXEY G8X...
AUCTION STARTS HERE @ 9AM (A52706)
AUCTION STARTS...
40' CONTAINER (A51244)
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
