Smoothing up some pastures.
   / Smoothing up some pastures. #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I am looking to clean up some property for planting next year. I have some stumps in the area. I am not planning on running a tiller over any stumps, but it might happen.
Maybe I am better off using a cultivator or ripper to break the ground first then use a finishing disc harrow.
Ideas?
I am looking at smoothing around 45 acres. The other 20 or so are smooth - just need to plant.
Thanks,
D.
   / Smoothing up some pastures. #2
Depending on what sort of tractor you have, a good reasonably priced alternative is to use a chisel plow at shallower depth than one would normally use one. Then disc. Old chisel plows are a dime a dozen around here. You just won't find many that a small tractor can handle. (Most are CAT II or CAT III hitch, and H.E.A.V.Y. too) Also consider an offset disc, or what was once popularly known as a "bog disc".
I have a J D5525. 75 HP PTO CAT II.
I have been thinking a used chisel might be the way to go to get the initial rip. I might not rip the whole thing, maybe just there we tore out stump 3 years ago. Break up enough dirt to spread it around.
D.
   / Smoothing up some pastures. #4
D.
You have enough tractor to handle an 8' to 10' chisel at a reasonable depth (in soils typical in MY area anyway)
I found this one locally.
10 Foot Wide Chisel Plow
That might be a perfect fit.
Hit it with a chisel and then disc and then spike harrow. I wonder if those chisels have springs, etc.
D.
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
2011 JCB 541-70 TELESCOPIC FORKLIFT (A51242)
2011 JCB 541-70...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
2014 VOLVO VHD DAYCAB (A50854)
2014 VOLVO VHD...
2005 GROVE RT700E ROUGH TERRAIN CRANE (A50854)
2005 GROVE RT700E...
