sixgun
Bronze Member
I have the factory blade setup on my 2710 and just went through my first storm with it, and it worked great. I was worried about the front end being pushed around but it didn't happen. I wish the blade was wider than 60"!
This is my first winter with a front hydraulic angled snow plow mounted via a factory subframe to a B3030. It works awesome. I find myself wishing I had a longer driveway than the 80 yards that it is. Because I can angle the plow I am able to push more snow that I thought possible. When the side wind-rows get too big, it is FEL or snow blower time. I recommend it!
gdh, 60 inch or 72 inch plow?
Went to a 72 hydraulic angle this year and I am happy as a clam. Wonderful setup I have if I say so myself. Main driveway is asphalt other two are crusher run and the barn area is grass and dirt.The width of the plow also depends on the surface. Now that mine is set up right it will lift up the front and push the tractor slightly to the side on asphalt. If you are plowing over gravel you would not lift the front up and not have that problem. I personally would not want a 72 but I have a B2920 and my driveway is 1200 ft of asphalt and about 9 ft wide.
