Snow Attachments Snow blower info
/ Snow blower info #1
Tags
Platinum Member
Connecticut
BX2360/ Kubota SVL90-2/ Kobelco 115SR/ Takeuchi TB260
I'm looking for three point hitch snow blower info,never had one before or ever seen one in operation.Just looking for feedback on which ones are so-so and which ones are good from your experiences.It will be used stricktly on asphalt and will be on a 43 hp machine (33 pto hp) ,so any and all info would be greatly appreciated,I know I'm lookin' in the right place /w3tcompact/icons/wink.gif
/ Snow blower info #2
Hi Chris - I use a pull-forward type blower made by Sno-Machines (no longer available I'm told) It does a great job on my place because most of my doors are in drive-by locations. The back-up type blowers do a better job of getting closer to things - lots of brands - 25 pto hp is plenty for anything up to 6 feet wide. Here's a pic of my rig.
Take care, Dick Bargeron
/ Snow blower info #3
You have lots of options. Pronovost, Buhler, Loftness, Meteor and so on.
Are you looking to buy brand new? Otherwise, I'd keep my eyes open on the roadsides - plenty of used machines out around me.
I have a Pronovost Puma but can't say that I did any research - it's just what was on the dealer's lot. I like it, though a remote chute control, whether electric or hydraulic is certainly worth it. Mine doesn't have one and when I clear next to a building and the wind suddenly shifts, I sure wish it did.
/ Snow blower info #4
I bought a Pronovost Puma two weeks ago from Gagne in Sutton Que. Its 72 inch and worked very well on the 8 inches of snow we had that weekend. Only trouble I had was it would scape up rocks the size of coconuts from the driveway then choke on them. I learned how to change shear pins, but haven't learned yet how to properly adjust the angles.
I guess I need more practice.
/ Snow blower info #5
Hi Tags:
There are a variety of options for 3ph snowblowers. First there are forward facing and rear facing. Both have advantages and disadvantages. Then there are single stage and two stage. Single stage use the speed of the auger to dishcarge the snow while a two stage use the auger to feed the impeller. There are also twin auger machines.
Most snowblowers are two stage so the following comments are geared that way, but the same principles apply to single stage machines. There are two factors that determine the effectiveness of a snowblower - discharge velocity and fit between the impeller and the drum. Discharge velocity is a function of the rotating velocity and diameter of the impeller. You need to consider how far you want to throw the snow. In my case I want to throw the snow about 100 feet so I need a discharge velocity of at least 5000 feet/min. My snowblower has a 20" impeller that I run at 1000 rpm which gives me a discharge velocity of about 5200 feet/min.
The fit between the impeller and the drum also affects the throw. The larger the gap, the more leakage and less throw. The fellow that made my machine gave me a rule of thumb to use - it was that a machine in good shape will pick up a dime at the bottom of the drum and carry it to the point of dischage a quarter turn later. Over time the blades of the impeller will wear and the drum may become damaged from rocks, etc. If it gets to the point that the impeller blades can't pick up a quarter, it is time for a rebuild. The throw of my machine had become much less than I thought it should be so I rebuilt it last year by putting a sleeve in the drum. When I put it back together I ground the impeller blades to give a 0.020" clearance between the impeller blades and the drum. That fixed the problem. Of course, the wetter the snow, the less throw a machine will have.
You also have the choice between new and used machines. There are a lot of good used machines around but you have to check the condition of the gear boxes, drive chains and sprockets, impellers and drums carefully. There are also considerable differences in quality of new machines - I have seen some with gaps between the impeller and drum as large as a quarter inch.
Then there are other ammenities. Snowblowers frequently blow snow where you don't want it - in your face. Therefore the question of protection becomes an issue. A cab is nice but pricey. Another option is remote control of chute direction and discharge angle. Some machine have electric controls for one or both while others use hydraulics.
Finally there is the quetion of power. My rule of thumb is 5 hp per foot of snowblower. With the amount of power you have, you shouldhave no problem with a 6 foot or even 7 foot plow.
Hope this helps.
/ Snow blower info #6
Boy, there is sure a range of engineering quality out there too. I recently looked at a Buhler for sale at a local tractor dealership, a 48 or 54" dual-stage 3-ph unit. To drive the auger, which feeds the snow into the blower, the shafts had OPEN bevel gears! It seemed a little crude to me, a former farm kid. Most farm machinery is still very crude technology, but at least they would have used an enclosed oil-filled right-angle gearbox if it was farm-rated equipment. Maybe that's the norm for blowers,but, it turned me off instantly.
/ Snow blower info #7
<blockquote><font size=1>In reply to:</font><hr>
<hr></blockquote>
Yeah, I was real surprised to see this on a friend's 5' John Deere blower (don't know the model, and I doubt Deere built it).
The weak point on my 75" Meteor blower is the unprotected auger chain drive. I have replaced 2 sprockets, a bearing and a chain in 4 years. I have about 500 ft of crushed stone driveway east of Buffalo, NY, so this blower has seen some use. I think the damage has all been due to stones from the driveway getting between the chain and sprockets. I made the repairs myself, so I only have about $100 in parts.
/ Snow blower info #8
I have the 60" Meteor. I only used it a few times last year on my 1500' gravel drive. I am a bit concerned about the open sprockets as well. Where do you get the replacement parts for your 75"?
Until the snow gets packed, I run it with the shoes extended then pull them up. It runs like a champ.
/ Snow blower info #9
I bought a 54 inch Pronovost Puma blower last year for my BX1800.I like the 1/4 inch steel they use.This will really throw the snow.Would like to see a tractor like yours throw the snow.I lke the way this one is put together.I haven't had any trouble with it.
/ Snow blower info #10
The open sprockets are not a problem as long as you keep them aligned, the chain resaonably tight and well oiled. You can get new sprockets and chain at most farm equiment dealers. Stones and snowblowers do not get well together.
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
2007 Oshkosh S-Series TMMB 11 Yard Front Discharge Concrete Mixer Truck w/ Tag Axle (A59230)
2007 Oshkosh...
TEREX RL4 LIGHT PLANT (A60736)
TEREX RL4 LIGHT...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2009 Cadillac CTS Sedan (A59231)
2009 Cadillac CTS...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
