Dave M7040
Elite Member
- Joined
- Dec 10, 2012
- Messages
- 2,757
- Location
- Williamstown Ontario Canada
- Tractor
- Kubota M7040 Nuffield 465
At the other end of the shaft I am working on is a small sprocket that drives the auger chain. It has 3 bolt holes connecting the sprocket carrier to the shaft. They would work as shear bolts, if they break the sprocket will turn freely on the shaft. I am not planning on using them as shear bolts as it would be a very inconvenient place to install new bolts when packed with snow.
The sprocket location is where your shear bolts should be. Being closest to the overload when it occurs ensures that shock loads do not end up in your gearbox.
The turning sprocket and chain keep that area clear of snow. Many blower manufacturers suggest starting with fewer shear bolts than the 3 and only increasing the number if they break frequently..
Most blowers have the splined coupling welded to the sprocket shaft. It will be a much more durable connection than the pin one which as you saw on your blower lead to the coupling breaking.
Dave m7040
