Snow blower?
/ Snow blower? #1
dustin3207
Bronze Member
St.stephen MN
Yanmar YM1602D
What Size snowblower do you recommend for my size tractor?
I have 16 hp pto. Was thinking maybe a 60"?
/ Snow blower? #2
First and foremost!!!!!!!!!!!!!!!!!!!!!!!!!
If its rear mount you want or need, it has to be/it must be as wide
as the rear tires outside width or a bit wider to prevent the
tractor from getting stuck trying to rde up on the sides of
the snow banks.
Then you can play with the money in your wallet as you can then
decide how much you can afford to spend on it.
The nice thing about a rear mount is you can use it on the next mule as
long as its the same width or trade it for wider one in when you trade mules.
/ Snow blower? #3
60 may work for you, it depends on the depth and water content of the snow. But most likely a 48 inch one would best suit you and even that would most likely be under powered at times when the snow is deep and heavy.
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
Gorman-Rupp O4A13-F3L Centrifugal Pump (A64912)
Gorman-Rupp...
2002 STERLING LT9500 SERIES CRANE TRUCK (A67714)
2002 STERLING...
2019 Nissan Versa Sedan (A66738)
2019 Nissan Versa...
2006 SUPERLINE DO20T192ALP T/A 20FT TRAILER (A66091)
2006 SUPERLINE...
