Snow Attachments Snow Chains
   / Snow Chains #11
Bigboyskioti said:
First my situation... I have a 600' concrete drive. It's all of 2 months old.
Good Lord man...are you using that concrete drive as a runway? :) That is quite an investment in concrete you have.
   / Snow Chains #12
Bigboyskioti said:
Looks like you have them on front and back? Is that better?
Depending on conditions the front chains can be more important than the back. When everything is a sheet of ice the tractor is very sure-footed with chains all around. Handles snow-covered fields and woods roads too. We have a nice snowboarding hill - we put couch cushions in the front bucket and the tractor becomes a great ski lift. With chains on all four corners it goes anywhere - slow, but steady.
   / Snow Chains #13
Destructo_D said:
with that said, I think the chains you are trying to describe are called Duo-Grip, a common kind of snow chain used on tractors
Duo-Grips are the kind that have a tie between sets of "ladders". These work well because they hold the chain up on the tire lugs. Regular ladder chains tend to fall in between the lugs, particularly on R1's, and don't provide much traction.
Double Rings are ladder chains where the ladder section is made of pairs of 2" or so round rings rather than traditional chain. These dig into ice well, don't fall between the lugs, and they don't tear up the driveway as much as V-bar chains.
Take a look at Tire Chains by Tirechains.com for pictures. I have bought chains from them, and was happy with them.
For Bigboyskioti's situation, I would think that standard ladder chains, or perhaps 2-link ladders (essentially twice the number of ladders) would work best to keep the concrete nice. I'm on gravel, and use duo-grip v-bars on one tractor, and duo-grip double rings on the other. They are unstoppable.
Good luck.
-John
   / Snow Chains #14
The other nice thing about the double ring chains is that they tend to be self-cleaning. This can be quite an advantage in mud or snow, where other styles of chains can load up and stop working very well. I see a lot of farm tractors with the double-ring chains here in the Champlain Valley of Vermont... lots of clay in the area.
John Mc
   / Snow Chains #15
I just ordered these for all four. I was thinking if they dont suit my needs I would buy some more cross links and make them 2 link or even turn the rears into an "H pattern"
Photo courtesy of Tire Chains by Tirechains.com
   / Snow Chains #16
My rear tire chains are 4 link ladder type vbar. With my small tires they ride very rough. I installed a tranverse cross link between the ladders and it smoothed out the ride.:D
   / Snow Chains #17
I have never seen the double ring chains before. That website says they are the best ice and mud traction, is this true?
I need chains for an older Ford 3500 2wd loader. I always have trouble doing loader work because I loose traction all of the time and get stuck in the mud. I never travel on pavement with the tractor (don't have any) so it doesn't matter if I chew things up.
   / Snow Chains
The double rings aren't available for my tractor. But I did find an old set from the quad that fit on the fronts. Guess I'll bite the bullet and buy the ones for the rears. I would rather have them and not need them than to not have and need them. Thanks for the replies.
   / Snow Chains #19
They are hard to beat in mud and clay. That's why all the farmers around here use them. They are also very good in snow. If you are looking for the ultimate in Ice traction, that's a different story... Valby ice chains are great, duo-grips with v-bars or ladder-style with v-bars are good too... but none of those options beat double ring chains in mud, IMO.
John Mc
   / Snow Chains #20
As others have said, for ice, nothing beats a chain with some sort of spikes (v-bars, or some of the fancy ice chains). My Duo-Grip V-bars are much better than the double rings that I have on another tractor. When the V-bars do slip on the ice, they dig down and tear up the ice pretty quickly. Concrete would probably suffer the same fate.
For anything soft like mud, the double rings are better because they stand up very tall which give them a lot of bite. The ride is pretty rough on hard surfaces too, which would get old fast on a long driveway.
-John
2003 International 7400 T/A Heil 12 Yard Dump Truck (A55852)
2003 International...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2018 Caterpillar...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
