Snow Edge for FEL
   / Snow Edge for FEL #11
Whether you realize it or not, you are wearing the bottom of the bucket, making it thinner over time. Having a sacrificial replaceable edge allows you to wear it out and then replace it rather than eventually having to replace your entire bucket. Since tractors move slowly, the wear will be much less than say on a plow on a pickup which plows at a much faster speed. There is also wear on the driveway itself. Using a wood or plastic PVC wear bar, as suggested by others will save wear and tear on your cement or asphalt driveway.
Thanks, makes sense. Maybe I'll try some of the tips mentioned here!
   / Snow Edge for FEL #12
Probably an odd question, but what are the downsides to not using anything? I've just been using my loader bucket edge for the last 4 or 5 years on a paved driveway with no ill effects. I haven't really noticed any wear on the bucket edge or damage to the pavement...
My driveway has a decent grade from side to side to help move the water that comes off a hill. The bucket doesn't always land flat on the driveway, so I have some decent gouges in the pavement where one corner of the bucket caught the high side. Since then I've used some type of edge protection.
   / Snow Edge for FEL #13
how do you keep it on? just friction?
Yes, just friction. I use a short scrap of 2 x 4 and a 3 lb. hammer to install it. I usually have a couple extra pieces cut as spares but I haven't needed to use one during the season. I should say I use a 3 pt snow blower to remove the snow and then float the bucket for the trip back up the driveway to clean up the edges. This works for me in my situation but your results may be different.
   / Snow Edge for FEL #14
Another pipe on FEL question.. when cutting it on a table saw - what type of blade is best? do you have to use a slower speed (i just got a shopsmith which is variable speed) so it doent melt/get too hot and stick to the blade?
Brian
   / Snow Edge for FEL #15
Brian
Any carbide tipped wood blade will cut pvc or abs easily. I don't think you'll see any melting. I mounted the pipe to a 2x4 to run along the fence as a little insurance against rotating the pipe while I was feeding it.
   / Snow Edge for FEL #16
Brian
Nothing special just a carbide tipped rip blade.
   / Snow Edge for FEL #17
anybody ever try the pvc pipe on a snowblower edge?? I have a 700' gravel driveway and until I get a good pack it can gouge you know the drill.. wondering if that would help for the first couple snows or if it warmed up and had to start over... my wife has started helping now that we have the heated cab of the toolcat and she struggles the most with the pitch of the blower on the front..
   / Snow Edge for FEL #18
If the PVC breaks and goes through the snow blower, you will probably find out it was a bad idea. (Plastic gets brittle in frigid weather).
I have a steel pipe, with tabs welded on it to bolt it on, mounted on my plow. I would go that route.
It works very well, on my 325' of gravel drive, once I have packed down some snow.
   / Snow Edge for FEL #19
I use something called edge tamers. They are like little skis that you clamp on the edge of your bucket. I do a lot of snow removal on both gravel and asphalt and these work well on both. I used to use PVC but like others, kept breaking the pipes. If I need to scrape ice off the driveway, they come off in seconds with a ratchet. But I've learned to only scrape where I know the asphalt is completely flat and smooth - catch a crack in the asphalt and it rips up really easily.
I'd rate the edge tamers a "recommend" especially if your also doing any gravel areas.
   / Snow Edge for FEL #20
Which edge tamers did you get the 3 in or 4 in? I am going to get some before the snow flies here. I just take care of my own driveway. Gravel (well really limestone) and I ended up with a lot of it in the yard last year. I will also have to plow a path to the new barn for SWMBO. That will be over grass/weeds. I don't care terribly about the underlying plant life right now as that will be replanted in the spring regardless, but I do not want to tear up the ground.
The Edge Tamers seems like the solution I need. You give them 4 stars?
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
36FT. B-Tek Centurion 100 Ton Digital Modular Commercial Truck Scale (A56858)
36FT. B-Tek...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2008 International Bucket Truck (A55973)
2008 International...
