Snow Attachments SNOW PLOW RESTORATION
   / SNOW PLOW RESTORATION #31
All plows converted to FEL use need to retain the use of the chain lift as it lets the plow follow the terrain as designed. You lower the FEL to about the height it would be mounted on a truck and the chain allows the blade to "float" and follow the ground. No more bent frames.
   / SNOW PLOW RESTORATION #32
Northernmainer is on to something with the pin height. When you pin a plow onto a pickup, on level ground the main plow frame is horizontal or slightly downhill at the plow end. It should sit that way on your tractor. With the tractor, you can raise or lower the pins (loader frame) and change the angle of attack. That's useful when the drive is soft, as lowering the loader lets the cutting edge rise, pivoting on the shoes. When the ground is frozen, you can raise the loader and increase the cutting action of the edge. Loader is also useful if your drive isn't flat, as you can keep a constant angle of attack if you're willing to fiddle with loader height.
Jim
Ford 8510 (A53317)
Ford 8510 (A53317)
20205 Lucky Dak Electric Scooter (A55853)
20205 Lucky Dak...
2019 Ford F550 Chassis (A55973)
2019 Ford F550...
Case Titan 3530 (A56435)
Case Titan 3530...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2014 Nissan Altima Sedan (A55853)
2014 Nissan Altima...
