Snow pusher on gravel.
   / Snow pusher on gravel. #11
OP,
Does it get cold enough where you are for your ground to freeze up hard? If so, you could just run an edge guard (pvc pipe, etc) over your cutting edge until freeze up. I take my Edge Tamers off of my FEL bucket once we freeze up. The ground is hard as concrete until spring thaw, and the cutting edge can't touch the gravel.
It does get cold up here in Michigan, but it still seems like a lot of rock ends up on the sides of the lane even in January when the ground is frozen, but I may have to try a piece of PVC. Do you recommend 1" 1.5" or smaller? With my blade angled, will I have to worry about the PVC slipping off the end of the trailing edge?
   / Snow pusher on gravel. #13
When I had a plow truck, I used a thick walled plastic pipe I got from the oil/gas well operations around me. It helped a lot.
   / Snow pusher on gravel. #14
i would use something 2+ it does wear a bit and the smaller stuff has a pretty thin wall.
   / Snow pusher on gravel. #15
Well I have a CUT C/W pusher and rear blower and my drive is gravel.
My solution is to modify and weld on oversized shoes or skids.
On my blower they are 2 1/2 wide and about 10 ins long with ends turned up like skis.
Works 4 me.
These I leave on all season.
For the front clamp on O/S skids work well.
Search will reveal some folks that sell 'clamp on' skids, but I welded mine DIY.
   / Snow pusher on gravel. #16
I was just reading through this thread and was thinking that a 8' rake with the gauge wheels set just above the gravel.. and some sort of mold board attached to the rake tines old probably work pretty well...
   / Snow pusher on gravel. #17
I learned a couple years ago that a York Rake does a fine job
Then I learned that attaching a length of angle iron to it makes it GREAT for gravel & even clearing snow off unfrozen grass without damage.
   / Snow pusher on gravel. #18
I put a section of 1-1/4" pipe on the cutting edge of the blade on my little Farmall blade. Cut a slot with the plasma cutter wide enough to slip over the edge, then welded tabs on it, matching bolt holes in the moldboard, to keep it in place. I'm sure you could do the same on one of those, although with the extra weight, maybe go with a larger size, maybe 2" pipe.
It will pick an occasional few stones in high spots, but doesn't gouge in. I leave it on year round, and makes it a bit easier to grade dirt without gouging in also.
Thanks for the visual DJ54. If only I was a welder!:confused3:
   / Snow pusher on gravel. #20
I have adjustable pads on my UTV blade and bought Turf Tamers to use on my tractor bucket.
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A56857)
2025 ZWB 59in...
2019 CATERPILLAR 259D SKID STEER (A52709)
2019 CATERPILLAR...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
