Snowblower auger shear bolts
   / Snowblower auger shear bolts #11
I only use grade 5 on my meteor with the length such that there are no threads in the sheer area.
Threads are weaker and can chew up the hole.
Grade 5 is just hard enough to make a clean cut while grade 2 kinda slops B4 sheering and are harder to drive out plus they make the holes oval.
I use grade 5 on both auger and fan.
When needed the 5's sheer as they should and do it cleanly. In fact they just fall out on their own.
When I used 2's I needed a drift punch to drive them out.
PILOON, what Meteor do you have?
I got a 1.5" bolt in there and it did the job. Unfortunately a bit of the threaded area of that bolt even is still between the shear plates but most of it is non threaded. Seemed to do the job fine yesterday as I got the drive done. I can definitely fit a 1.75" bolt with more than enough clearance.
When I have a chance I'm going to head to my dealers to see what he sells for shear bolts. He's about an hour away and I'm not headed in that area for a bit.
   / Snowblower auger shear bolts #13
My meteor is a 60" and I previously had a 48" that got trashed.
It was on the 48 that I experienced worn out sheer holes from soft shear bolts, I upgraded to -5's from recommendations of others as well as info on TBN
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2012 RAM 2500 (A58214)
2019 C.GALLEGOS PNEUMATIC TRAILER (A58214)
2019 C.GALLEGOS...
1990 TRAIL MASTER  TRANSPORT TRAILER (A58214)
1990 TRAIL MASTER...
INOP Four Wheeler (A57453)
INOP Four Wheeler...
