Snowblower auger shear bolts
   / Snowblower auger shear bolts #11
I only use grade 5 on my meteor with the length such that there are no threads in the sheer area.
Threads are weaker and can chew up the hole.
Grade 5 is just hard enough to make a clean cut while grade 2 kinda slops B4 sheering and are harder to drive out plus they make the holes oval.
I use grade 5 on both auger and fan.
When needed the 5's sheer as they should and do it cleanly. In fact they just fall out on their own.
When I used 2's I needed a drift punch to drive them out.
PILOON, what Meteor do you have?
I got a 1.5" bolt in there and it did the job. Unfortunately a bit of the threaded area of that bolt even is still between the shear plates but most of it is non threaded. Seemed to do the job fine yesterday as I got the drive done. I can definitely fit a 1.75" bolt with more than enough clearance.
When I have a chance I'm going to head to my dealers to see what he sells for shear bolts. He's about an hour away and I'm not headed in that area for a bit.
   / Snowblower auger shear bolts #13
My meteor is a 60" and I previously had a 48" that got trashed.
It was on the 48 that I experienced worn out sheer holes from soft shear bolts, I upgraded to -5's from recommendations of others as well as info on TBN
2010 SHOP MADE LIMA MAC 30KW GENERATOR (A58216)
2010 SHOP MADE...
Harley Mototec Electric Scooter (A57149)
Harley Mototec...
2019 Case IH 370 Steiger (A57148)
2019 Case IH 370...
2017 WEILER P385B ASPHALT PAVER (A52709)
2017 WEILER P385B...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
