snowblower won't raise or lower
   / snowblower won't raise or lower #1
jugg
eagle river wi
john deere 425
i have a john deere 425 with a 47" snowblower have my hydraulic lines hooked up but the snowblower won't raise or lower. double checked hydraulic lines ok any suggestions would be greatly appreciated.
   / snowblower won't raise or lower #2
Reset your QD's if you have them.
Is the snowblower on the front or back?
on the front
   / snowblower won't raise or lower #5
Does the hyd lines flex when you try to lift?
Remove hoses from loader valve work port for the lift spool.
Push the lever to see if fluid flows. Just a little push.
Then note if the hose is going to the lift cyls.
The nut that holds the piston on the shaft might have came off, and that will let flow freely.
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2020 Caterpillar...
UNUSED FUTURE 48" LAND LEVELER (A54757)
UNUSED FUTURE 48"...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
