snowblower won't raise or lower
   / snowblower won't raise or lower #1
jugg
eagle river wi
john deere 425
i have a john deere 425 with a 47" snowblower have my hydraulic lines hooked up but the snowblower won't raise or lower. double checked hydraulic lines ok any suggestions would be greatly appreciated.
   / snowblower won't raise or lower #2
Reset your QD's if you have them.
Is the snowblower on the front or back?
on the front
   / snowblower won't raise or lower #5
Does the hyd lines flex when you try to lift?
Remove hoses from loader valve work port for the lift spool.
Push the lever to see if fluid flows. Just a little push.
Then note if the hose is going to the lift cyls.
The nut that holds the piston on the shaft might have came off, and that will let flow freely.
40" WIDE STAIRCASE W/ METAL RAILING (A54756)
40" WIDE STAIRCASE...
2015 HYUNDAI HL760-9A LOADER (A52705)
2015 HYUNDAI...
(APPROX 104) 2X4X10 PINE LUMBER (A54756)
(APPROX 104)...
UNUSED LANDHONOR LHR-MS0810 METAL SHED (A54757)
UNUSED LANDHONOR...
2014 CATERPILLAR 324EL EXCAVATOR (A52705)
2014 CATERPILLAR...
2009 Ford F-250 4x4 Ext. Cab Pickup Truck (A55788)
2009 Ford F-250...
