snowblower ?
/ snowblower ? #1
1999cobra
looking to purchase
Is there a snowblower available for the CK20HSD ? Didn't see anything mentioned on the website...
Mike
/ snowblower ? #2
Any of the 3pt rear mounted snowblowers would fit. Given the available PTO hp of the CK20, a blower of about 48" to 54" would work great.
I'm not aware of any front mount blowers for the CK20.
/ snowblower ? #3
I bought a Lorenz for my LK3054XS. They make them for all sizes, both rear mounts and front with a kit. This is a very expensive blower however, but well worth it. Any 3 point should work as long as it is the right width and designed for your horsepower.
Schulte is another good brand.
Dan.
/ snowblower ? #4
I ran a 60" with a Ford 17HP and a Cub 23HP in N NY. They both worked OK bcs
/ snowblower ? #5
I run a Normand Econor 72" blower behind my LK3054XS. It's a great combination.
/ snowblower ? #6
Mike
Kioti does not make one for their tractors.
There is a Kioti dealer in Canada that has made and supplied them to dealers.
I know the name of the dealership is Egger Tractor if you can not find anything let me know and I will try to get a hold of them.
They also make a snow plow.:)
/ snowblower ? #8
Where are you located Mike, maybe your in the same region as KiotiDave, I believe he carries the Normand econor snow blower and the E-60 would be what I'd recomend, I've use mine for two season now with no problem...
/ snowblower ? #10
Cobra
Are you looking for a front or rear blower?
/ snowblower ? #11
/ snowblower ? #12
I miss using my snowblower. :( Didn't use at all last year and my plow blade has been adequate to move the dismal 11" we've received this season.
/ snowblower ? #16
In Sept. I bought a used Buhler/Allied 50" rear 3 pt. snowblower for my CK20H tractor. The unit was in real good shape but beliveve it or not we have not had a big enough snowfall so far this winter to really test it out. I did make a mod on the crank angle for the shoot rotation to make it easier to reach. And I still may extent the crank but I don't want it to punch a hole in my fuel tank when the blower is raised up fully.
/ snowblower ? #17
IslandTractor said:
Man that looks cold. Makes ya wanna run right out and buy a tractor with a heated cab.
It really isn't that bad. I try and wait until the wind dies down before I clean. Prevents getting a lot of snow blown back in the face.
Actually, we have had a fairly mild winter for this area. Didn't have snow on the ground until after Christmas and only recently had about 3 weeks of -20C or colder at night. I really haven't gotten a lot of use out the blower this year, there is only about 6" of snow on the ground (touch wood).
/ snowblower ? #18
Here's a picture of my 60" JRB rear mount blower. I love using it for removing snow, but with a hilly gravel driveway, I found the plow truck much more effctive.
/ snowblower ? #19
That is a great looking unit. Are you saying that you don't use it?
/ snowblower ? #20
Yeah, I didn't even hook it up this year. I wish I had though, the diesel in the truck gelled up and once I finally got it going I plowed the 18" or more of heavy wet snow. The piles all around my driveway are about 10'-12' high. Good for sledding, bad for seeing cars coming. It was cold and early so I didn't feel like pulling off the backhoe and hooking it up. My driveway is very rough with random rocks and stumps sticking up, not very good for snowblowing. Once it's paved, I will probably go back to snowblowing, it is a much cleaner and better way to move snow, just longer. (Power service 911 is awesome!)
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A60736)
2014 MAGNUM...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
2017 FORD F-250(INOPERABLE) (A60736)
2017 FORD...
