Snowplow mount direct to tractor
   / Snowplow mount direct to tractor #1
Hay Dude
Epic Contributor
Top Poster Of Month
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
Anyone mount a plow direct to frame, just like on a truck (not on loader arms)?
Found nice 9' used blizzard plow with wings. Might go well on one of my kubota m's.
   / Snowplow mount direct to tractor #2
I had a sub-frame mounted snow plow on a L3130 Kubota.Probably the best for the tractor,but lift height is compromised and you lose the use of the FEL.My current set up is a eight ft. FEL mounted on a L4240 but I only have one tractor.
Looking for bigger tractor mounts or pictures. Found a guy in MI that does nice looking work.
   / Snowplow mount direct to tractor #5
I have western plow mounted on my Branson 2400H. I used the Western quick hitch mount from a Jeep and mounted this to the tractor frame. I can pull two pins, disconnect the hydraulic lines and install the FEL in ten minutes or less. Yes you are limited in lift height on the plow but it for me that is not an issue since if I need to push the piles back I just install the FEL.
I have no pictures of this on the Branson. Took the plow off a couple of weeks ago to mount the MMM so I could do some spring work on it.
   / Snowplow mount direct to tractor #6
I dropped two plates from the frame to pick up tubing arms that reach forward to pick up the A-frame points. I use a short cylinder to raise and push down the plow blade. The loader hydraulics provide swing and lift.
   / Snowplow mount direct to tractor #7
Check on Plowsite, some guys on there use some M's.
2026 tilt trailer (A56859)
2026 tilt trailer...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2019 KENWORTH T680...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
UNUSED IRGC40 HIGH END MINI GOLF CART (A60432)
UNUSED IRGC40 HIGH...
