Soil Separator
/ Soil Separator #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
Well I finally built a soil separator. I have attached a couple pictures. A couple of things I learned. The chain link fence doesn't work well with organic material, stuff sticks to it. I am going to see how much some expanded metal costs and try that, otherwise I will try some welded wire fence. When it is just rocks and dirt it works OK but the holes are too big to remove the smaller rocks. Using two layers of chain link doesn't help. I also built it just wide enough to get my bucket in to remove the good dirt. I should have made it at least 6" wider since I catch the bucket on the supports a lot. Also since it just slopes down to the ground when I go to get the dirt I tend to push the dirt farther forward and can't get it. If I had made it stop sooner and put a piece of ply that I could push against when scooping it would have helped.
/ Soil Separator
Lets try attaching the pictures.
/ Soil Separator #4
Just get what you can and when you're done sifting simply move the sifter over to 1 side and then use your loader to scoop up what you weren't able to get to while the sifter was in place.
I find it's better to till the dirt before sifting it.
Makes for smoother easier sifting with better results.
/ Soil Separator
I was clearing a drainage ditch in front of the house and I got some dirt with the brush. I wanted to burn the brush and since dirt doesn't burn well I was trying to seperate it. I gave up on that and just burned it. The pile smoldered for about 4 days after the burning. Also I am seperating teh rock from the spoils after roch hounding some of the yard. These piles have three years of weed growth. I took off a layer of chain link last night and added twolayers of some welded wire. I will see how that does with the smaller rock. My soil is very sandy with a lot of rubble. I want to plant the pasture this weekend so the mounds need to go.
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
2004 Quincy QSI500 Air Compressor (A61572)
2004 Quincy QSI500...
2003 FORD F-650 SUPER DUTY CAB & CHASSIS TRUCK (A64276)
2003 FORD F-650...
2002 Hyster C330B Articulated Tandem Drum Vibratory Roller (A61572)
2002 Hyster C330B...
KUBOTA DM5032 HAY BINE (A64280)
KUBOTA DM5032 HAY...
