Raspy
Veteran Member
- Joined
- Dec 16, 2006
- Messages
- 1,636
- Location
- Smith Valley, Nevada
- Tractor
- NH TC29DA, F250 Tremor, Jeep Rubicon
GT2,
From your brief description I can't say too much.
Using gypcrete instead of the tube fin systems is a very good idea. I avoid fins at all cost and have found them to be completely unnecessary. Even if you have no mortar of any kind, avoid the fins.
A very large built in storage tank like the one shown is OK. It's a lot of work! Use a lot of storage and not so many panels to avoid overheating in the warm season. I have ben associated with a couple of systems like that that had up to 1200 gallons of storage. One had only, I think, 6 collectors. It as on the coast and worked quite well with little or no backup. One that I built had an above ground storage of 1000 gallons with 6 collectors and a small propane tankless water heater for backup. This one has gypcrete and the first one had concrete floors.
Often these type systems must have relatively large pumps and corrosion can be a problem or the fiberglass tanks can be a problem. I have an exceptional corrosion inhibitor that I use that is non toxic and lasts the life of the system. I also have a love/hate relationship with Grundfos pumps.
We can get into much more details if you'd like because I love talking about this stuff.
I don't know what you mean by a solar loop running through a propane fired water tank. Do you mean just plumbing a water heater in series as backup?
Some info on delivery temps and strategy in an in-slab radiant system might help. 90 degrees is just about break even. It will hold the house and raise it some, but very slowly. 120 degrees is all you'll ever need and should be about the limit you ever send to the floor. Maybe a bit more under special circumstances. There are three phases of floor temperatures. The first is cold. Meaning you notice it right away and don't want to be bearfooted, the house feels cold. Next is invisible. This means you just don't notice the floor when walking on it. The house is generally pleasant. The floor is probably around 70-75 degrees. The third is where the floor greets you when you walk into the kitchen or bathroom. It's very nice and gets your attention. This is good for entries and bathrooms and it is probably about 80 to 90 degrees. Any floor warmer than about 87 degrees for an extended amount of time will heat the house to where you are too hot unless there is very poor insulation.
Using the floor for storage can be helpful, but it is likely to be more of a problem. A minimum threshold temp is fine, but above that we become uncomfortable and a slave to the system. Radiant floors are most comfortable when we can vary their temps. Some examples of this are: Sleep in a cool room and arrive in a warm bathroom in the morning. Let the bath cool during the day. A warm kitchen floor in the morning but cooler during the afternoon. Guest bedrooms cold until needed. One kid likes his room warm and the other likes it cool. An office might get morning sun and have a lot of computer heat loss. But is used at 3:00 in the morning and needs heat then. The entry floor might be warm in the evening and settle down during the night to save energy. Etc. Programmable thermostats are definitely your friend. Outside sensors are a waste of time. Generally speaking, setting and leaving the thermostat at one setting means a variable inside temp because of all the other influences such as the sun, cooking, lighting, activity, etc. A varying thermostat setting matches the house to the users and saves anergy. Measuring the outside temp in order to decide the delivery temp does not take into account that we want to change the floor temp and do it relatively rapidly in order to accommodate our lifestyles.
Feeding the floor with 90 degree water will not drive the floor to 90 degrees because of the heating load. But 90 degrees at the solar panels is very efficient.
Try not to ever send any heat from your backup system into your storage system. This is very important and means you will have to find a way to switch to backup and direct that energy to the floor only. This can be done with a heat exchanger that heats a closed loop floor system from the open loop tank. The closed loop circuit can also be diverted through a backup heater that is also part of that loop. Switching is done with differential solar controllers and circulators. You can choose solar only, automatic, or backup only.
Thanks for putting up with my ramblings.
John
John
