solar-thermal panels
/ solar-thermal panels #21
So far I haven't puled the trigger. Maybe it's the temps up here, -40 in the winter to 100 plus in summer and the temp of the water, but a number of people I talked to who have the 'regular' panels (copper tubes) have all told me they worked well for about 10 years and then started to leak. While they were able to repair the leaks each time meant draining out the antifreeze and just got to a point where it was too much trouble so they no longer used them. Now most of the panels I've seen look very white like it's not glass but plexi or something covering the face of the panel. That could mean they are not expensive panels.
Most of the local dealers around here I just don't trust. They run ads on the radio saying how in a few years you can pay off solar electric panels. After looking into it and finding out I needed to invest $36k into a system and may get $6k back from the gov for a system that has a life expectancy of about 30 years it's barely a break even option in a state that just doesn't get the sunshine like some of our southern states.
One local dealer said he didn't sell the Evac tubes because they tend to get covered with snow, not really an issue for me, and then quickly moved to electric panels so I lost interest. Until I found someone who can give me an honest opinion I'll probably just wait as my costs of heating water really aren't too bad.
/ solar-thermal panels #22
I have a closed loop glycol system, and live in the wasatch mountains of northern Utah. My system consists of 2 viessmann flat plate collecters, a HT Products 80 gal indirect tank, with boiler backup, a Callefi differential controler,A thermostatic mixing valve, and a Grundfos pump(120v). I built my house 2.5 years ago, and planned ahead for the system, with the install of an indirect water tank(indirect meaning the water is heated via a heat exchanger, so there is no flu in the top of the tank, to lose heat through) and roughed in piping to my roof. I agree with earlier posts about evacuated tube collecters, in my opinion, they are not worth the extra expense. My system delivers 75-80% of my family of 4's hot water needs, averaging of course, the system delivers 100% in the summer months, and less in the winter. My panels are orientated 17 degrees off of true south(to the west) and pitched at 45 degrees. I've read in earlier posts about heat dump methods,but what sold me on my system, is that with only 2 panels, and pitched at 45 degrees for optimal winter gain, it greatly helps to keep the system from over heating in the summer, so I haven't needed a heat dump as of yet. My indirect tank is usually at 170 - 180 degrees in the summer, so I'm definately close to maxing out at times, but has not been a problem as of yet. Like I mentioned earlier, I have a mixing valve installed on the outlet of my indirect tank, which adds cold water to the hot, to insure the water never exceed 130 degrees to my household fixtures.
I have done a tremendous amount of research on the subject, and would be happy to answer any questions, just PM me, as I'm not always checking the forums
I posted about my system last year, do a search for solar hot water in the projects forum.
/ solar-thermal panels #23
It sounds like you guys have great systems that you understand well. I like that! Solar heating is such a wonderful addition to a home when it really produces some good results. Unfortunately it is only seen as a business oportunity for some and a chance to make a quick buck. Or sold by someone with good intentions that experiments at the homeowner's expense. This is the problem I've been up against since the 70s.
Now the PV companies are becomming very succesful. I don't do PV on homes, but have been informally asking everyone I can how they like it, what the payback is and what problems they've had. Very interesting indeed.
I get every answer from "I don't know, but I feel like I'm doing my part", to "definitely not worth it because of the problems" to "it's great". Some staunchly defend systems that do nothing, while others monitor every penny. And some put the systems in, just so they can justify using a lot more electricity. Builders install systems just as a sales pitch and put the equipment in the most ridiculous positions on roofs never intended for them.
It seems in many cases you can't save enough to pay the interest on the loan. Or equipment fails that is no longer under warrantee and kills the overall savings. Then the installers send out notices that the collectors must be cleaned and some maintenance done. Unfortunately, this cost approximately equals the annual savings.
I think we are in the beginning of a great shift in consciousness about energy in general. We won't give up anything, but we must find ways to do it differently. In the beginning it was all driven by tax breaks, but eventually it will be driven by energy costs. Hopefully, it will also be driven by the need to be independent of those we buy oil from.
/ solar-thermal panels #24
When I built my house a few years ago I made sure I could tie a system into it. The roof pitch is 12:12 and it positioned it so I have a roof facing as close to south as possible.
I have a direct vent oil fired Bodurus boiler sitting atop a 57 gallon tank they make. Having a mixing valve on the output is code. I have it set up so I could add a second tank that feeds the 'cold' water to my primary tank. I also made it to use a pump to circulate water between the two tank when the solar tank gets above the set point of my primary tank.
Any system I install I would like it to be as maintenance free as possible. I don't mind working on things but it always seams like everything needs to be worked on at the same point in time.
/ solar-thermal panels #25
crazy,
I like the 12:12 roof pitch for the panels.
I install a lot of indirect DHW systems in the new homes I work on. These boilers also do the radiant heat.
The boilers around here now are all high efficiency and run on natural gas.
I'm building a new home for my wife and I on five acres in northern Nevada at about 4900 feet elevation. It will be in slab radiant and I want to use oil for the heat source, so I'm beginning to look for a high efficiency condensing boiler that runs on oil.
We're now living in the little guest house on the place that is only about 430 sq.ft. It has an electric hydronic radiant system in the kitchen/bath and a wood stove. With R38 insulation and double pane windows it's actualy hard to keep the temp cool enough even with the smallest fire. We keep wondering why we need to finsh the big house instead of just making it a shop for projects. Meanwhile the steel is going up.
/ solar-thermal panels #26
I got advice from those same people with good intentions and put in sand beds. I have overcome the poor performance and made them useful again. It took a few years of experimenting but ok with it now and probably would use again now that I understand the requirements and dynamics better.
I agree Wetspirit, has been happening for a few years but the masses are getting bombarded with going green, remember that only one letter separates green from greed! I read your other post about your new house, I have had the same thoughts about tiny house and big garage for years!! Good luck with the project and share some pics if you will so we can learn even more!
/ solar-thermal panels #27
My bodurus is a direct vent but isn't the condensing version. I got the computer control for it that controls things like an automatic mixing valve for the radiant heat. t uses the out door temp to decide how hot the water needs to be as well as monitoring the DW temp to keep it up to temp. I figure by having the water circulation between the primary tank and the solar tank the computer will be smart enough to know not to run the boiler. I went with oil because I'm at the top of a long driveway and I can always buy oil if I run out. I don't have NG as an option and propane needs a truck for delivery.
My house is a post and beam built with foam panels, if you have a chance look into stress skin panels. I have radiant heat throughout but I also have 42 acres of hardwoods so I mainly use the wood stove. Even in the -40 temps we reach in Northern VT I only use 2 to 3 cords of wood. So basically my boiler has turned into an occasional back up to heat the house and how I heat my domestic hot water. I use about 150 gallons of oil a year so there's not too much in savings with solar panels for me. But like you said we need to be moving away from oil and I like the idea of not having to pay for hot water.
/ solar-thermal panels #28
I sure would be looking into a wood fired boiler of some sort with storage with all that available firewood. Although sometimes it is easier to buy your energy than exert energy to get it.:) $450 a year is not bad though for all your hot water AND back up heat! Do you have enough floor area to carry the house heating needs?
/ solar-thermal panels #29
Back to freeze protection and long system life. The best way to design the system is with a method to drain the collectors by gravity when there is no sun or any kind of failure in the system. Do not depend on power to protect the system! In other words, no recirc freeze protection, no electric valves that take power to drain the system, etc. This will make the system much more reliable and more efficient. My favotite is drain back. This is where there is a small holding tank, approximately 4 gallons. that holds the collector water at night. When the collectors warm up, the circulator pushes the water up to the collectors and the air that was in the collectors is stored in the small tank. Then, when the power fails or when the sun sets, the pump stops and the water drains back to the holding tank and the air moves back to the collector. Beautifully simple, no toxic or expensive antifreeze, no mineral buildup, no pressure in the collectors, etc.
I've been thinking of building a system like this for a while. I'll describe it and you guys can give me some feedback?
Build the system like the guy did here SolarShed in Montana.
An open loop system with a large storage tank.
Run the hot water thru a solar loop inside a propane fired hot water tank and then to radiant floor loops in 1.5" gyp creet on the floors.
For back up I was thinking for using a wood boiler hooked to a copper tube grid (acting as a radiator ) placed into the water storage tank.
This would be for a 4000sq ft home and garage in N. Idaho.
Do you think this would work?
/ solar-thermal panels #30
I like the boiler part but will defer to Wetspirit as this is more of his expertise.
/ solar-thermal panels #31
GT2,
From your brief description I can't say too much.
Using gypcrete instead of the tube fin systems is a very good idea. I avoid fins at all cost and have found them to be completely unnecessary. Even if you have no mortar of any kind, avoid the fins.
A very large built in storage tank like the one shown is OK. It's a lot of work! Use a lot of storage and not so many panels to avoid overheating in the warm season. I have ben associated with a couple of systems like that that had up to 1200 gallons of storage. One had only, I think, 6 collectors. It as on the coast and worked quite well with little or no backup. One that I built had an above ground storage of 1000 gallons with 6 collectors and a small propane tankless water heater for backup. This one has gypcrete and the first one had concrete floors.
Often these type systems must have relatively large pumps and corrosion can be a problem or the fiberglass tanks can be a problem. I have an exceptional corrosion inhibitor that I use that is non toxic and lasts the life of the system. I also have a love/hate relationship with Grundfos pumps.
We can get into much more details if you'd like because I love talking about this stuff.
I don't know what you mean by a solar loop running through a propane fired water tank. Do you mean just plumbing a water heater in series as backup?
Some info on delivery temps and strategy in an in-slab radiant system might help. 90 degrees is just about break even. It will hold the house and raise it some, but very slowly. 120 degrees is all you'll ever need and should be about the limit you ever send to the floor. Maybe a bit more under special circumstances. There are three phases of floor temperatures. The first is cold. Meaning you notice it right away and don't want to be bearfooted, the house feels cold. Next is invisible. This means you just don't notice the floor when walking on it. The house is generally pleasant. The floor is probably around 70-75 degrees. The third is where the floor greets you when you walk into the kitchen or bathroom. It's very nice and gets your attention. This is good for entries and bathrooms and it is probably about 80 to 90 degrees. Any floor warmer than about 87 degrees for an extended amount of time will heat the house to where you are too hot unless there is very poor insulation.
Using the floor for storage can be helpful, but it is likely to be more of a problem. A minimum threshold temp is fine, but above that we become uncomfortable and a slave to the system. Radiant floors are most comfortable when we can vary their temps. Some examples of this are: Sleep in a cool room and arrive in a warm bathroom in the morning. Let the bath cool during the day. A warm kitchen floor in the morning but cooler during the afternoon. Guest bedrooms cold until needed. One kid likes his room warm and the other likes it cool. An office might get morning sun and have a lot of computer heat loss. But is used at 3:00 in the morning and needs heat then. The entry floor might be warm in the evening and settle down during the night to save energy. Etc. Programmable thermostats are definitely your friend. Outside sensors are a waste of time. Generally speaking, setting and leaving the thermostat at one setting means a variable inside temp because of all the other influences such as the sun, cooking, lighting, activity, etc. A varying thermostat setting matches the house to the users and saves anergy. Measuring the outside temp in order to decide the delivery temp does not take into account that we want to change the floor temp and do it relatively rapidly in order to accommodate our lifestyles.
Feeding the floor with 90 degree water will not drive the floor to 90 degrees because of the heating load. But 90 degrees at the solar panels is very efficient.
Try not to ever send any heat from your backup system into your storage system. This is very important and means you will have to find a way to switch to backup and direct that energy to the floor only. This can be done with a heat exchanger that heats a closed loop floor system from the open loop tank. The closed loop circuit can also be diverted through a backup heater that is also part of that loop. Switching is done with differential solar controllers and circulators. You can choose solar only, automatic, or backup only.
Thanks for putting up with my ramblings.
John
/ solar-thermal panels #32
Google Image Result for http://www.evergreenenergy.ie/img23.gif
http://www.google.co.th/imgres?imgu...mage_result&resnum=4&ct=image&ved=0CBwQ9QEwAw
Here is a automatic wood burning boiler. Works like gas or oil. Google biomass or wood chip boiler.
I know a guy who made a fully automatic horse manure boiler for his horse stables. He would just put few front loaders of manure in the hopper every few days. He couldn't find a manufacturer so unfortunatelly there is only one prototype.
/ solar-thermal panels #33
GT2,
John
John, thanks for the " ramblings", very helpful.
I saw a standard looking tank propane water heater that had a copper coil in the bottom for running external solar water thru. To pre- heat the tank.
I thought I could run the solar water thru it first then on to the floors, or would there be too much temp drop?
I plan to use different loops in different areas like you describe. I will use thermostatic controllers on the manifolds also.
So your saying do not use back up heat to heat the storage tank? If possible, elaborate?
Your saying use a heat exchanger on the incoming line to the heating system itself instead of the storage, and / or by-pass the storage tank itself?
Thanks, Tim
/ solar-thermal panels #34
The house is a post and beam with foam panels so it requires very little to heat even on the coldest nights. I have a small to mid size soapstone stove that I can run all night, usually the biggest problem is I over heat the house and wake up to mid 80's in the living room.
The house is 1900sqf, not too large but the living room walls are 12' with a 12:12 pitch roof so it's about 22' high. All the rooms on both floors connect to it so spreading the heat from the stove isn't hard. If I went with solar panels it would be mainly for DW heating only and most likely from April to October. Those are the months the furnace would never run.
/ solar-thermal panels #35
I've been toying with the idea of adding some myself. I've been looking at the evacuated tube style. They may cost more but from what I've been told the style with the copper tubes that run back and forth tend to expand and contract and leak. Here's a link:
http://www.rstreps.com/pdf/install-vacuum-tube.pdf
The water only goes across the header and if a tube breaks the system still works. Plus they are suppose to work better in shade.
Be careful. I love the technology of the evac tubes...in some areas. In Vermont you get a lot of snow. The evac tubes do NOT get warm on the outside so snow does not melt off them as well as other collectors. What makes them efficient at absorbing heat also keeps the outside too cool to effectively melt snow.
Peter
/ solar-thermal panels #36
I was under the impression you had storage tanks already. How much storage would you be considering for the DHW? How much of your house has radiant floors? The way I understand how you heat is that you use a wood stove and use the radiant floors for back-up, when you are gone lets say? Is this correct?
/ solar-thermal panels #37
Peter
I'm not too worried about snow since I really don't care about using them in the dead of winter (I'd be happy with April to October) and with a 12:12 pitch roof snow doesn't stay up there. However there was a link to a website at the beginning of this thread that had a link to a couple of side by sides of the two. What one of them found is that the evac tubes frost over and don't thaw very quickly. That could mean the loss of a month or two so I doubt I'll go that route.
/ solar-thermal panels #38
The whole house has radiant floor heat. I love walking barefoot in the middle of winter on the tiles. I have a 57 tank right now but have the plumbing in place to add something like a Rheem 80 or 120 gallon tank.
Because my furnace isn't the type that just stays hot I was thinking on having a circ pump that would turn on once the storage tank reached a temp higher than the primary tank. That way the solar panels would also heat up the primary tank. If the temp of the solar tank drops below the set point the boiler would keep the primary tank at temp and just be fed warm water from the solar tank. That way the furnace should never come on unless we (my GF and I) used up both tanks.
/ solar-thermal panels #39
When do you use the floors for heat:confused: You burn 2-3 cords of wood to heat the house but have radiant floors:confused: Do you run the floors off the water heater or have the boiler and the wood stove going at the same time? Please clarify for me how you use what you have in place at the moment.
/ solar-thermal panels #40
Tim,
I'm not sure you'll want to run the radiant water through the water heater on the way to the radiant system. On the way to the radiant storage tank, yes, but not on the way to the radiant floors. If you have a separate water heater with a loop, as you describe, you might just run the solar panel return line through the water heater heat exchanger on it's way to the main storage tank that will then heat the radiant later. The radiant schedule is not the same as the hot water schedule. And the radiant system can operate at a lower temp than the DHW. Plus, hopefully, you won't need to store energy in the radiant floor. At least no more than to bring it up to a threshold temp.
On the radiant manifold loops. Yes, be sure to run different loops for different rooms. 1/2 inch barrier PEX is the most practical tubing and the loops should be set up to be relatively close in length. Arrange them at 9" or 12" on center with a 6" OC first pass near entry doors and in the bathrooms. Bathroom loops can be considerably shorter than bedroom loops because we want higher flow rates in the bath. Try not to exceed 300 linear feet per loop. Three 200' loops would be better than two 300' lengths. Loops can run through hallways to get to bedrooms and kitchens, etc. This heats the hall without a thermostat in that area and provides a convenient run of tube. I run all tubes above the floor, meaning don't go to the trouble to route tubes in joist bay spaces. Sometimes this means very close tube spacing in a hall, for instance, and that's fine.
You mentioned thermostatic controllers on the manifold loops. I want to be very specific here, so bear with me. I only use telestats, or motorized valves. No thermostatic valves that attempt to regulate the temperature going through them or of the temperature of the floor. This leads to a bigger conversation, but the theory is to move a lot of water at an adequate temp, as opposed to a regulated flow at a certain temp designed to hold the floor at a certain temp. Thermostatic controls fall into the category of "maintaining" a certain temp all the time. Telestats fall into the category of delivering heat rapidly, and actually do it more evenly and effectively. The proper control strategy is to use a wall thermostat that is programmable, or in some cases, a floor sensing thermostat. Rapid flow at an adequate temp is the idea here. To understand the thinking here imagine a room with serpentine radiant piping. Maybe it has 15 runs across the room at 9"OC. The hot water comes in and moves back and forth across the room, giving up energy and cooling as it goes. A very slow flow will mean a large differential between the supply hot and the return cool. This means that the room got progressively cooler and cooler supply water in different areas and therefore will be cooler, and heat slower, in different areas. It also means we deliver less energy to that room, in total, than if the water was flowing faster. Faster means more even heat and more energy delivery. A floor gives up it's heat to the environment based on the temperature differential between it an the room. A warmer floor equals more delivery to the surroundings. A small differential in the radiant supply and return temps means more energy delivery than a large differential because all of the floor experienced the warmest water. So, a warm relatively high flow makes the room heat the best and delivers the max energy.
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2020 International LT625 48" Sleeper (A62613)
2020 International...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
1992 Rammax 7430 Trench Packer and Extra Set of Drums (A62613)
1992 Rammax 7430...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A65053)
2018 GENIE GTH-636...
