Some questions about Deere engines
   / Some questions about Deere engines #11
One thing for sure is the torque rise from the extra cylinder.
   / Some questions about Deere engines #12
I really liked the old Mercedes 5 cylinder engine that had factory turbos.. 120 hp...Lots of get up above 45 mph. This same engine was born a 4 cyl. in smaller cars.
   / Some questions about Deere engines #13
What is also strange is that JD used that 5cylinder in the 5225 and 5325 and then used a 4cylinder in the 54,55,5625's in previous years. Strange.
   / Some questions about Deere engines #14
Well... I think you answered the basis of my position. 75 Hp from the 179 cu. in. powerplant is likely at the upper limit and using it in a heavier chassis (with cab, too) tractor could shorten the "duty-cycle" for that powerplant. That's not a situation that JD wants for their "flagship" optioned tractor that is positioned for heavy duty applications with a long service life.
The 4.5L 4-cylinder powerplant turns out 85Hp while "yawning" with 8-9psi turbo boost. It's understood that turboing an engine also serves to "clean up" the emissions and fuel efficiency as well as increase power output. Dropping the turbo for a naturally aspirated engine for placement in the 65-75Hp range would likely "dirty" the emission's and make the engine fall out of the Tier III-IV rating's.
Check over the stat's here: TTL test reports/JD Deere
Good reading - and note that the 5 cyl. in the 75M is neck and neck with the torque output for the 85M!!
AKfish
That just made me mad cause I own a 5085M, MORE TURBO BOOST! :laughing:
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56438)
2017 John Deere...
Case 1020 25ft Draper Head (A56438)
Case 1020 25ft...
White 5100 / 6900 Planter (A59814)
White 5100 / 6900...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
