Some questions about Deere engines
   / Some questions about Deere engines #11
One thing for sure is the torque rise from the extra cylinder.
   / Some questions about Deere engines #12
I really liked the old Mercedes 5 cylinder engine that had factory turbos.. 120 hp...Lots of get up above 45 mph. This same engine was born a 4 cyl. in smaller cars.
   / Some questions about Deere engines #13
What is also strange is that JD used that 5cylinder in the 5225 and 5325 and then used a 4cylinder in the 54,55,5625's in previous years. Strange.
   / Some questions about Deere engines #14
Well... I think you answered the basis of my position. 75 Hp from the 179 cu. in. powerplant is likely at the upper limit and using it in a heavier chassis (with cab, too) tractor could shorten the "duty-cycle" for that powerplant. That's not a situation that JD wants for their "flagship" optioned tractor that is positioned for heavy duty applications with a long service life.
The 4.5L 4-cylinder powerplant turns out 85Hp while "yawning" with 8-9psi turbo boost. It's understood that turboing an engine also serves to "clean up" the emissions and fuel efficiency as well as increase power output. Dropping the turbo for a naturally aspirated engine for placement in the 65-75Hp range would likely "dirty" the emission's and make the engine fall out of the Tier III-IV rating's.
Check over the stat's here: TTL test reports/JD Deere
Good reading - and note that the 5 cyl. in the 75M is neck and neck with the torque output for the 85M!!
AKfish
That just made me mad cause I own a 5085M, MORE TURBO BOOST! :laughing:
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2016 Lincoln Navigator SUV (A59231)
2016 Lincoln...
2016 Deere 180G (A60462)
2016 Deere 180G...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
