Source for "Kickout Ring" aka "Circular Cotter" ring/pin?
   / Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Looking for small quantity source for what are known as "kickout rings" a version of the circular cotter ring or pin. OD is a hair or two under 2 inches.
These are used to secure some pins on 3pt implements and I am bound to lose some one way or another. It is a lot easier to have spares on hand than to try and rig up a "it'll do for now" deal.
I've found some, but either too small or 100 minimum. There gotta be some, somewhere.
Turns out Kubota has a part number for it 67156-34340. So, that settles that. Except, being as cheap as I am, I'll keep looking for substitutes.
   / Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #3
Check McMaster Carr. Should've a lot better prices:
Tried. A bit small.
   / Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #5
I think what you are referring to is called a lynch pin and you can find them at almost every farm store or Tractor supply etc.
   / Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #6
Sort of looks like they range from $2.25 to $2.75..... Bailing wire is probably only thing cheaper...
It's the shipping that gets me. I'll just order some next time I need other parts.
   / Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #8
Not that I'd recommend it...
   / Source for "Kickout Ring" aka "Circular Cotter" ring/pin? #9
Harbor Freight assortment in the barn and no complaints...
I've got a box. Used a couple already, seem fine. I'd like them better if the pin had a flat on one side.
2025 AGT YSRT14 (A50123)
2025 AGT YSRT14...
Trojan 50CL 40mm Hydraulic Hammer, New  (A52384)
Trojan 50CL 40mm...
John Deere 772-A Grader (A52384)
John Deere 772-A...
B&W Companion Sliding 5th Wheel Hitch (A53117)
B&W Companion...
2013 Buick Enclave SUV (A51694)
2013 Buick Enclave...
1839 (A51248)
1839 (A51248)
