Speaking of mower blades
   / Speaking of mower blades #11
On my old Murray and the 2 newer Sears mowers I put on a pair of leather gloves, raised the deck to the highest setting, use a 9/16" socket and ratchet, hold one end of the blade with one hand (remember the gloves?), and take the bolt out that holds the blade(s) on. BTW, I have to lay on the ground to do this.
I also put a light coat of grease on the blade bolt before reinstalling so it won't be too hard to get off next time. I go through at least 2 sets of blades a year because the sand eats the ends of them off pretty quickly.
Check the deck for a decal that shows the belt routing. If it is not there then hand draw a picture for yourself for future reference, you will most surely need that information some day. The last Sears I had needed a new belt at 3 years old but I use it a lot since we mow nearly year around in East Texas.
Bill Tolle
   / Speaking of mower blades #12
I bought an electric hoist from HF for $80, mounted it through the ceiling into the rafters of my shop. Drive the mower under the hoist, throw a lifting strap around the front axle and hoist her up. /forums/images/graemlins/smile.gif I do put a couple of safety stands under the front wheels.
   / Speaking of mower blades #13
</font><font color="blue" class="small">( I bought an electric hoist from HF for $80, mounted it through the ceiling into the rafters of my shop. Drive the mower under the hoist, throw a lifting strap around the front axle and hoist her up. /forums/images/graemlins/smile.gif I do put a couple of safety stands under the front wheels. )</font>
This is what I do /forums/images/graemlins/wink.gif. G
   / Speaking of mower blades #14
</font><font color="blue" class="small">( I bought an electric hoist from HF for $80, mounted it through the ceiling into the rafters of my shop. Drive the mower under the hoist, throw a lifting strap around the front axle and hoist her up. /forums/images/graemlins/smile.gif I do put a couple of safety stands under the front wheels. )</font>=====-
How strong are the frafters?
How much weight will they support.?
   / Speaking of mower blades #15
LBrown59, The ceiling in my shop is 1/2" OSB on 24" centers. I nailed two eight foot 2/4's and straddled four ceiling joists then built U brackets to go over the "beam" and through the ceiling to attach to the hoist. I don't know what the load rating on the rafters are, but I have used the hoist on a JD 318 and did not have any sag or creaking. I use the hoist probably four or five times a week for things other than sharpening blades and have had no problems. /forums/images/graemlins/wink.gif
   / Speaking of mower blades #16
</font><font color="blue" class="small">( LBrown59, The ceiling in my shop is 1/2" OSB on 24" centers. I nailed two eight foot 2/4's and straddled four ceiling joists then built U brackets to go over the "beam" and through the ceiling to attach to the hoist. I don't know what the load rating on the rafters are, but I have used the hoist on a JD 318 and did not have any sag or creaking. I use the hoist probably four or five times a week for things other than sharpening blades and have had no problems. /forums/images/graemlins/wink.gif )</font>
Thanks for this post.
I just wanted and idea of how I could put a hoist in my shop safely.
The last thing one wants is if for it to come crashing through the celing.
   / Speaking of mower blades #17
If you don't have a lift. Drive mower into pickup, put saw horse under back of the boards you usedto load and push mower back onto these, now you can get to under side.
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
2014 Peterbilt 337 Service Truck (A53422)
2014 Peterbilt 337...
2014 DRAGON 500 BBL FRAC TANK (A53843)
2014 DRAGON 500...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2012 KENWORTH T800 (A53843)
2012 KENWORTH T800...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
