Spiked Tooth Harrow
   / Spiked Tooth Harrow #1
MtnViewRanch
Elite Member, Advertiser
4000\' mountains of Southern California
Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
I have been thinking about getting a spiked tooth harrow with a 3 point hitch to go over my ground after I've disked it. Hoping to smooth-even the ground out. Do any of you use one, and if you do, are you happy with the results? Does anybody use the adjustable angle spikes, or are they not very sturdy? Are the fixed harrows a waste of time? Should I be using a different type of implement?:confused: I have about 70 acres that I normally disc twice a year. I use a 12' disc on most of it and was thinking about a 14' harrow.
Thanks
   / Spiked Tooth Harrow #2
I'm not a very good authority on harrows, so for what it's worth: Spike tooth and spring tooth types don't get much play here in the midwest from grain farmers who do mostly no-to-low till. However old, even crappy, units sell good at auctions. I think people want them for lawn prep and/or for going over pasture land to break up and spread manure clumps and uneaten hay where they feed in the pasture without a hay bunker. For work behind a disc, I would check out the newer chain link style. Should do a better job (more even) because of their flexibility. 14' sounds fine behind a 12' disc. Unless you a pulling a heavy offset disc you may be able to pull both at once for one-pass operation.
Fred
   / Spiked Tooth Harrow #3
I'd have to see this 14' spike tooth harrow you're talking about before rendering a specific opinion. But it seems to me that a chain harrow might be more appropriate to your needs.
//greg//
   / Spiked Tooth Harrow #4
I have used spike and spring tooth harrows as conditioners and they do work well. The only downside I've had with them is clogging. A true disc harrow (as opposed to the disc plow) will cut through clods/roots/trash but will not level or smooth as well unless pullling a heavy drag.
Nontheless, they do work and depending on the condition of the soil your working can work very well.
   / Spiked Tooth Harrow #5
Thanks
I use one of those harrows .. see http://www.tractorbynet.com/forums/attachments/89973-field-drag-drag-harrow-ii.html
While they will level to some extent, a box blade or a grader blade will yield quicker results ...
I love this harrow though, I use it for may things .. arena grooming, manure busting, field thatching .. etc.
At first I was thinking about the Atlas Spike Harrow, but then it would be better with more than 4 rows so I have been considering this 5 row heavy duty adjustable harrow. Or would I be better off with a chain harrow.
Unfortunately I do not think that I would be able to have the harrow behind my offset disc. I have 32, 22" 6 gauge notched blades cutting in the dirt 8"-9" deep.:) At a little over 4000lbs total weight I don't have the extra 25-30 HP to spare.:( That is why I was thinking something with a 3PH and getting more seat time, or maybe a bigger tractor so that I could do it in 1 pass.;)
So now what would your thoughts be?
   / Spiked Tooth Harrow #7
Brian, I made one from Re-Bar a long time ago and mine will pull out small brush and level ground with nice smooth hills and I live in Florida and the ground is soft here. I tried the chain and the fence and it did nothing for me, The spike harrow is the way to go. I don't have any pictures of it but I can get some in a few days. Northerntool.com makes one similar to mine. Here is link
Howse Spike-Tooth Harrow — 3-Point, 7ft. Length |Category 1 Attachments | Northern Tool + Equipment
Jim:)
Jim, the Northern Tool harrow is like the Atlas Spike Harrow that I have a link to. This type of harrow seems like it would be the easiest way for me to get this done if they do indeed work. And the Spike tooth harrows seem that they are easy to move around & to store. So you are happy with yours and the way that it works?
   / Spiked Tooth Harrow #9
Yeah Brian, with that disc and assuming you pull it with your 7520, I imagine the disc alone is pretty much a full load. My dad farmed with a 2N Ford, had a 10' Ferguson single disc & a 12' 5-bar adjustable harrow. Pulling the disc over plowed ground was no strain, the harrow was practically no load. I hooked them together one spring. WOW! The load increase was phenomenal. Much more than I expected from their individual loads. Seems the draft of the harrow hanging behind the disc pulled it down making the disc cut deeper plus it was waaaaay back there. Overloaded. I finished one field & went back to 2 pass operation. That's why I said "unless you are using a heavy offset disc" when I mentioned the possibility of tandem operation.
Fred
Fredex, I wish that my 7520 would pull that. I have an old Cat D6 that I use. My 7520 is pretty much maxed out with my 8' offset disc. Same make up as the 12 footer, just 20 blades instead of 32. I would use the 7520 with the harrow after I was finished disking. Do you think that I could go wider than 14'?
Thanks
Peterbilt (A51692)
Peterbilt (A51692)
GooseNeck Trailer (A52377)
GooseNeck Trailer...
2010 NORMA G20 GENERATOR (A55745)
2010 NORMA G20...
2005 Honda Accord LX Sedan (A55853)
2005 Honda Accord...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A53421)
2018 Bobcat T590...
