Splitter Regen Valve for Power Beyond
   / Splitter Regen Valve for Power Beyond #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
I am looking for a log splitter regenerative valve that will work on a Power Beyond System and be stackable with others for lift and a hoist winch units. Plan to use on my BX25 using the BH ports. The Prince LSR 3060 mentioned in previous posts does not meet those criteria. Maybe I am whistling Dixie on this but need to make that decision before I proceed with my project.
Ron
   / Splitter Regen Valve for Power Beyond #2
The data for the LSR 2060 says
SPECIFICATIONS:
1. Max design and test pressure 3500 PSI
2. Max tank port pressure -150 PSI
3. Nominal inlet flow rating 4 gpm
4. Standard relief valve setting – 2250 psi
It doesn't say regen, but.
Perhaps you could get away with that valve, it says nominal,
I don't believe I have ever seen a log splitter valve advertised with regen.
JJ, it is a Prince LSR 3060-3 not 2060. Cylinder Services Inc. has them, Surplus Center does not. My dilemma is continuing the PB circuit and also adding the two other circuits.
Ron
Thanks J.J. Problem is the ports may be too large for my little 7 GPM BX. I am toying with using a open/close spool in a stack with the winch and lifter valves and then put the 2060 down stream from that.
Ron
   / Splitter Regen Valve for Power Beyond #6
You can always adapt port and hose fittings to suit your needs.
Dosko Stump Grinder (A45336)
Dosko Stump...
2015 MACK CXU613 SLEEPER TRUCK (A43005)
2015 MACK CXU613...
Massey Ferguson 2605 2WD Tractor (A47809)
Massey Ferguson...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A43005)
2019 INTERNATIONAL...
Dynapac CC122 Roller (A47809)
Dynapac CC122...
JMR 36in Bucket (A47809)
JMR 36in Bucket...
