Starter on Carroro 68.4
   / Starter on Carroro 68.4
Hey
I've a honed a cylinder . What do you think?
Do i need to do it a bit more ? or does it look alright?
How do i get it to top dead centre ?
Thanks
T
Ok thanks . How do i mesure to check the limite of material with a tool ?
Thanks
T
Yes , i'm useing 10w20 diesel oil if that's allright.
By the way . How do i get the engine to top dead centre ?
   / Starter on Carroro 68.4 #59
When the piston is at the top of the cylinder, it is at top dead center (TDC)
1 and 4, TDC, bancer weights will be down. 2 and 3 TDC, balancer weights will be down.
Balancer shaft turns two times to every one turn of crankshaft.
Hey
Sorry for late reply . So i v'e honed the cyclinders as much as i dared and cleaned the pistons and rings and bearing and put 3 of them back in. i broke one of the rings on the 4 th piston so i've ordered some new rings . I thought yesterday to try and turn the engine over with the starter to see if it was the engine or starter that wouldn't turn it over before so i connected the starter to the battery and it just sparked like before . So i tried turning the engine over by hand . i had to use a metre long bar to turn it . Is that normal for a rebuilt engine ? i turned it over when all the pistons were out and it turn fine . Is it the starter then ? I've cleaned everything in the starter and the brushes look really good as well as the armature . The only thing that's missing the the rubber seal at the end .
Anybody got any ideas ?
Thanks for the help really appreciated .
T
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
2013 International DuraStar 4300 Altec L42A 42FT Bucket Truck (A55852)
2013 International...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
2011 KENWORTH T800 (A55745)
2011 KENWORTH T800...
2011 Ford Escape SUV (A55853)
2011 Ford Escape...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
