Starter problem
   / Starter problem #11
I replaced mine with the same symptoms. The starter was bad.
As a non mechanical dude, I found the replacement refreshingly easy.
However, about a month later the carberator needed replacement. That's when I traded up to a compact tractor.
Buck
   / Starter problem
The whole dang problem turned out to be a bad battery, of all things. I made the wrong assumption that the starter was bad because my 50 amp booster would not start the mower. I think my booster is way worn out. I did get the educational experience of tearing the starter apart, cleaning the brush contact area and wrestling it back together (what a pain)./w3tcompact/icons/mad.gif After a while I got smart and hooked my RV battery up and whaddyaknow, it fired right up. $21.99 spent at Sears later, the rider is back in business and the walk-behind is back in the shed where it belongs. /w3tcompact/icons/grin.gif Sometimes the stupid alarm goes off and I just don't hear it. /w3tcompact/icons/blush.gif
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
SUV (A59231)
SUV (A59231)
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
TANK MANIFOLD (A58214)
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
