starter selnoid
   / starter selnoid
Just want to make sure you understand......if the PTO light is on,your starter will not engage. I'm not sure you need a new starter at this point.
I removed the starter and tried it straight to a new fully charged battery and grounded with cables. Did same thing extended but does not spin. I have check all switches and the one that troubles me is the mid pto. It has four wire 2 green and 2 yellow. When i test it it the 2 green wires show closed when the lever is engaged. I can engage it and its open. So i assume it is working properly.
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
406 (A52706)
406 (A52706)
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
