Starting Pole Barn site prep. Admin this is a dupe please delete this
   / Starting Pole Barn site prep. Admin this is a dupe please delete this #1
PowerTracManiac
Central, Virginia
Power Trac 1460
Thinking 48ft wide by 36ft deep.
Any thoughts on the height? I was thinking 12ft minimum inside with 9 ft tall doors.
Also looking for a pole barn builder that will travel for work in central Va. 20240229_154227.jpg
   / Starting Pole Barn site prep. Admin this is a dupe please delete this #2
Build as big as you can afford. If like me, it will fill up over the years with jacks, drill press, welders, lathe, Bridgeport etc. Stuff you never thought you needed. Make at least one part that you can heat, with the rest storage. The doors should be as high too. Think of the things you may carry or boom in on a chain without looking up. I came close to hitting the 12' doors many times. Good luck.
SCREENER (A58214)
SCREENER (A58214)
2017 Ford F-650 Mason Dump Truck (A59230)
2017 Ford F-650...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
