starting problem
/ starting problem #1
jayjay75
yanmar 2500
Just bought a yanmar 2500 i think is like late 70s model .when i bought it the battery was dead so they jumped it and it started and ran fine.drove 3 hrs home went to pull off of trailer and nothing ..changed battery and still nothing any ideas .is there something im doing wrong please help
/ starting problem #2
What exactly is the problem? Is the engine cranking over and not starting or is it not even cranking? If it's not cranking, is the clutch depressed and is the clutch safety working, any other safety switches not engaged? If it is cranking over, do you have any smoke coming out of the exhaust, if so, what color is it?
/ starting problem
It doesnt make a noise no clicking no nothing checked clutch switch seems to be good
/ starting problem
What other safety switches are there and where are they located
/ starting problem #5
It likely has a safety switch at the transmission...make sure any/all shifters are in neutral. It also likely has one at the PTO, so make sure that isn't engaged. Lastly, it may have one on the seat, so make sure you're sitting on the seat when you try to start it.
/ starting problem
Is the one at transmission internal or external ..also is there a site i can download a manual
/ starting problem #7
Safety switches should all be external.
Check the starter wires etc, maybe one let loose in travel.
/ starting problem #8
That has to be a safety switch Check all the connections make sure they are tight also check the ground and make sure it is clean.
/ starting problem #9
I've got a Yanmar 276D. 1987(+- ) There is a safety switch on the clutch and that is it on mine. I recently had a starting problem. No power. It turned out to be a previous repair problem. There was a male/female connection that was barely making contact. Possibly the vibrations from your road trip loosened up an already marginal connection.
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2016 John Deere 6155R (A64119)
2016 John Deere...
John Deere 4020 Loader Tractor (A66285)
John Deere 4020...
4004SFL (A59228)
4004SFL (A59228)
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
