Steering on 1600 series MF
   / Steering on 1600 series MF
Sounds like the steering cylinder may be by passing.
I agree. Just wondering if its normal or not? Maybe like a pop off valve on a turbo? There is a lot of weight on the front axle (steering issue has seemed worse since adding my grapple, which weighs about twice as much as my bucket). Maybe its designed to by pass fluid at a certain PSI to reduce the risk of damage to tires and front axle when turning the wheels back and forth and not moving??
   / Steering on 1600 series MF #12
Its not designed to by pass. There are o-rings and seals inside the cylinder that sometimes break or my have been torn from the installation. If it is still under warranty then i would take it back to the dealer and have them check it out.
Thanks. I'll call the dealer and set something up. Its still under warranty.
   / Steering on 1600 series MF #14
I have had mine be hard to steer at a dead stop. Once I start moving its easy again. I have ran cranes, lulls, and backhoes that have all done it at one time or another.
   / Steering on 1600 series MF #15
Sorry all of those machine had hydraulic steering too.
   / Steering on 1600 series MF #16
Tried mine parked on concrete at idle speed and wheels turned freely both ways.
   / Steering on 1600 series MF #17
You do not have a problem. All hydraulic systems have to have a pressure relief valve, if not a hose would burst or the pump or something else would have to break when you turned the steering to the far right or left. If you were to put enough weight on the front of a car it would do the same. Your problem is the extra weight of the grapple. My MF 1250 will do the same if the bucket is half loaded and on hard soil.
Thanks for explaining that. I called my dealer and he told me exactly the same thing.
   / Steering on 1600 series MF #19
That is great news. Since we do not have a loader, or front mount anything, I was not sure if it was normal or not.
Thanks.
   / Steering on 1600 series MF #20
Yes, thanks. My 1635 will do the same thing once in awhile with a full bucket. Good to hear that it is normal.
2021 Ford F-350XL (A57148)
2021 Ford F-350XL...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56435)
2012 MACK Tender...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
towable flood lights (A56857)
towable flood...
2010 Freightliner Derrick Digger (A55973)
2010 Freightliner...
utv cart Honda (A56857)
utv cart Honda...
